Yak 86" Ballance
RE: Yak 86" Ballance
Thanks HarisH. Appreciate it. Well i took the cowl off today to find the Ignition Battey and ignition module came loose. I was lucky.
Both were mounted on motor box with thick foam and tie straps. How do you stop it from failing?
