questions regarding QQ python
Old 02-15-2009, 04:46 AM
tommy7120
Default questions regarding QQ python
Hi Rezagh
I have a QQ python with a 3W 110b2 CS 12.8 hp.
The question refers to the engine Canister with D70 mm.
I have problems with having them in the channel to the Canister. There is no more than 1-2mm on each side.
3W said the engine was not tested with D55 mm Canister, then 3W discouraged me to buy the D55 mm Canister.
I wonder if there will be too hot in the channel.
Which servos should I use? I intend to use HiTec HS-5985 as the servos . Is this okay?
What propeller should I use when it should not exceed 94 db in the club? A 2 blade or 3 blade propeller?
Best regards
Tommy
tommy7120 is offline
Old 02-20-2009, 09:15 PM
Rezagh
My Feedback: (73)
Default RE: questions regarding QQ python
Tommy,
Servos will be OK! As for the dba nd propeller you need to experiment that. 3 bladed props with higher pitch and carbon fiber are quieter!
Does two 70mm diamter can fit in the tunnel?
Thank you,
Reza
Rezagh is offline
Old 02-23-2009, 12:51 PM
tommy7120
Hi Rezagh
Thanks for the quick reply.
In these pictures you can see what I have done. There is not much space.
Best regards
ID:	1143039   Click image for larger version
ID:	1143040   Click image for larger version
Old 02-23-2009, 08:24 PM
Rezagh
My Feedback: (73)
If it doesn't expand that they touch each other, you should be fine but keep an eye on it especially if you are flying 72mhz and not 2.4. another problem that I just saw is that the cans are sitting on the balsa floor and there is no silicone around them, I am afraid you can damage the frame or even have small burnt spots on the balsa. Those cans are big for that tunnel! I wish you could use smaller cans.
Rezagh is offline
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service - Do Not Sell My Personal Information
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
