Difference beween the 101" & 102 QQ Yak
CA
Gentalmen:
Could anybody give me a breif run down on the difference between the 101" and 102" QQ Yaks. I realize that the 101 incher supports the DA-85 and the !02" is best suited for the DA-100.
Thanks all
M0f0sheee
My Feedback: (73)
RE: Difference beween the 101" & 102 QQ Yak
Hi There,
101 has a longer nose to help with more precision flying and tracking. It actually has the same wingspan as the 102" but for the sake of differentiating between the two is called 101. It also will balance with DA85 with ease that will reduce the wing loading from 102, so you will have a 100cc plane in sub 25lbs range with high precision flying performance.
Hope this helps,
Reza
Hope this helps,
Reza
CA
Reza:
I thank you for the brief and to the point synopsis that you have provided to me. I came across a used 101 with all the trimmings at a reasonable price. Looks like a buy to me. Thank you
M0f0sheee
