Spektrum Telemetry System for Mystique 2.9 ARF
Hi,
I would like to build a system for Mystique 2.9 electric glider, that includes DX6 (Spm6750), a suitable receiver, and a telemetry system with vario and GPS (with voice). I planned a Spektrum system, but I am not sure: AR610 6-Channel DSMX Coated Air Receiver (SPMAR610) TM1000 DSMX Full-Range Aircraft Telemetry Module (SPM9548) Aircraft Telemetry Variometer Sensor (SPMA9589) Aircraft Telemetry GPS Sensor (SPMA9587) But TM1000 has only 1 x-bus connector. Can I use 2.5" Aircraft Telemetry Y-Harness (SPMA9553) to connect them? Or how should I connect these devices? Thanks in advance, Pisti |
All the xbus modules connect in series . You plug one into the 1000 and the next into the one you plugged into the 1000 and the next into that one and so on.
Thanks Larry.
