RC 1/8th Scale Buggies Discuss the ever popular category of 1/8th scale rc buggies in this forum!
what pipe?
Old 01-27-2012, 10:36 AM
schuttman
schuttman's Avatar
Location: m\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'boro, TN
Default what pipe?
Looking for a good low-end to mid-range pipe, ideas anyone??
Old 01-27-2012, 10:56 AM
nitroexpress
nitroexpress's Avatar
Default RE: what pipe?
tsais t32
Old 01-27-2012, 11:40 AM
HerrSavage
Depends on the engine of course.. But 053 maybe..
Old 01-27-2012, 12:03 PM
nitroexpress
Just having a spot of fun. For all we know, the engine is a Traxxas TRX3.3
Old 01-27-2012, 08:17 PM
schuttman
schuttman's Avatar
No Traxxas that is for sure. I picked up a Ofna Ultra that has maybe a 1hr run time on it, it has a force 28 with real good compression,
now I know this is not the best engine, but I'll run it till it gives out. The engine is a little slugish on the bottom end but real good on mid
to upper rpm's, I have been at rc's for a long time and the engine is tuned, just looking for some ideas on a decent pipe.
Old 01-27-2012, 11:31 PM
HerrSavage
I would look for a used 053 on ebay, or maybe also an RTR Losi buggy or truggy pipe - the "HD" pipe I think it's called... Good and cheap..
Old 01-28-2012, 07:33 AM
jmaxey51
053 kills power, makes it smooth... look at a JP3, when ever you need power, JP3 is the pipe. run time wont be as good as 053 though....
just my opinion
Old 01-28-2012, 07:48 AM
supertib
supertib's Avatar
ORIGINAL: schuttman
what kind of clutch does it have ? and how high do you have the idle set ? 2 things that will kill your bottom end are the RTR clutch and having the idle set too high..........buying a new pipe wont fix your lack of bottom if your idle is too high and the clutch is fading
Old 01-28-2012, 10:40 AM
sparky 25
sparky 25's Avatar
The stock ultra pipe is just a straight through pipe and is extremely loud,
I fitted an ofna 053 pipe to my ofna buggy with the force 28 motor and power is greatly improved,
Excellent bottom and midrange power over the stock pipe.
Old 01-28-2012, 10:50 AM
HerrSavage
I had an 053 on a Caster Grenade(Go 5-port) and it gave great bottom end - almost too much like a light-switch.. Was great on that engine.. Top end was great too as a matter of fact..
Lots of people over the years though have said the 053 is good for Machs and LRP's, but when I tried it on both those engines I thought it killed top end... I always thought it was more of a bottom to mid type pipe...
Old 01-28-2012, 01:33 PM
schuttman
schuttman's Avatar
The clutch is like new three shoe alum, and theidle is set low, I don't like my cars idled high it makes them a little tough to drive for me,
good info though. Keep in mind this is just a backyard basher me and some buddies have tracks in our backyards, just new to Ofna. I went thru the car when I got it and everything was in excelent condition. How about diff oils? I started out with a Associated diff oil set up front7000 cent10000 rear5000.
Old 01-29-2012, 11:24 PM
lez1troubles
Try a set of heavy springs in your clutch, that way your engine will need a bit more revs before the clutch actually bites and will accelerate harder.
Old 02-01-2012, 07:12 PM
schuttman
schuttman's Avatar
Thanks for the idea onclutch springs. I will try that and I'm going to put a 53 pipe on it also. Thanks to all for the ideas
Old 02-01-2012, 08:54 PM
Dr. Blockhed
Keep us posted on how this turns out, I.m going through the same thing with my ultra, upgrading the clutch and springs also, but I'm running a jp3 pipe.
Old 02-02-2012, 07:41 PM
schuttman
schuttman's Avatar
So how do you like the jp3 pipe? I will post some pics after i get the body painted from tear down to complete.
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
