GO .21 idle
Location: m\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'boro, TN
1 Post
GO .21 idle
I have a GO .21 that has been broke in, I haverun a couple of tanks thru it at speed, and the engine runs good, I just can not get it to idle down correctly.
It takes a couple of seconds to idle down. I have adjusted the idle on the carb with no luck, run the throttle trim down withno luck.
I have other engines that run perfect that I have tuned. I have been running nitro cars for a long time, I know I am just missing something or over looking the obvious. HELP
RE: GO .21 idle
hey, i would try the low end needle thats what i do um try richening and leaning but it depends what porting 2,5,7, i used to have the 7 port and i found that it loved rich setting but the idle was bearly open . http://www.youtube.com/watch?v=WqtM5SkvQG8 here this was my old one before it wore out and died hope it helps
