Nitro Engine Mounting Standards for Savage & Hyper 7 Buggy......????
Hello
I've just had both my Savage and Hyper 7 engines start to fail, they're both Big Block engines and have been rebuilt several times and have been very well maintained, but life for them both is basically over. I've been looking at new alternatives, Alpha, NovaRossi, Werks, HPI.....etc.....etc..... and I can't find any standards with regards to the mounting similarities of these new engines in relation to my old engines.
My main concerns are these:
1) Are the mounting holes on the bottom of the engine the same on all Big Block engines....?
2) Is the dimension (Height) from the "engine mounting face" to "output shaft centre" the same.....?
(......or do engine manufacturers just sell interface/mounting plates to suit whatever vehicle it's going to be mounted to attain correct position & height).......?
I've searched the internet high and low for these answers and just have come up blank, they must get discussed regular......!!!!
Any help would be much appreciated.
Cheers
Johnny
Cheers
Johnny
The Savage (I believe) can only use a pullstart or roto start engine...any engine that is described as big block with the appropriate starting system will fit.
The Hyper 7 can use bump/pull/roto and has engine mounts that will move the engine fore/aft...again any big block will fit.
Generally there is always a way to make an appropriate engine fit/work in a car...for example...
The LRP.28 pullstart engine has a very large backplate....the engine fits the Hyper 7 mounts but the backplate is so large that you can not fit the mounts to the engine mount plate and thus the chassis......however by cutting out a section of the mount plate and using a few spacers under the mounts you can get it to all fit together.
My advice is to look at the engine you want for each vehicle and then either come and ask if it will fit or just do an internet search...eg- Hyper 7+LRP
The JL.28 that comes on the US Hypers is the Force .28...HPI use them
In the UK we still get the option of the Hyper.21 or the Macstar.28 on the Hypers.
There is also a new engine...a .30 that looks to be based on the Hyper.21/Macstar.28... http://www.cmldistribution.co.uk/pro...ox-servos-blue
