When adjusting wheel alignment
NM
When adjusting wheel alignment camber, where is the chassis suppose to be? All the way up/down?
I noticed as the chassis moves, so does the camber degrees.
To consistently adjust ride height, you want to firmly press on the chassis until it bottoms out, then release and measure the ride height. Some folks will drop their buggies from varying heights and that can lead to inconsistent ride height measurements which can consequently yield inconsistent camber readings.
You need two blocks to put under the chassi, what you use doesn't matter as long as you always use the same and they are straight. If you're going to use someone else setup you need to know what they used so you're reading the value from the same chassi height.
https://www.hudy.net/xhudy/products/...4510581eae1db8
NM
I'm not quite understanding how blocking the chassis helps in finding the natural driving height, since there doesn't seem to be one with loose off-road suspension. I off-road like 4x4's, not just using dirt tracks. A balance between high speed runs and off-road fun. Maybe I have a suspension adjustment issue. I'm new to cars, I was into hobby helicopters where precision is required.
It doesn't find anything, it just lets you have the same point to adjust from. Changing ride height is done beside that, though for racing it's often very little that is changed regarding ride height.
If you're going to run very high ride height then you might want to use taller blocks, but then you have to change things if you're going to run on a track. A lot of droppe is usually not the best idea for track.
