Shock spacers
Shock spacers
Ok. I don't get it. Don't make fun of me, but I don't understand what these are for. Take a lok at my pic, what is the difference between the left shock and the right shock. Technically, their stiffnes is the same, what difference does the piece of plastic make?????????????????????????????????????????????? ?????????????????????????????????????????????????? My thought is that using the plastic spacers the springs top ring that compresses them doesn't come loose. HELP, i know this may be really retarded for many of you , but I don't know. Thanx
MO
RE: Shock spacers
The spacers are a cheaper alternative to threaded shock bodies, but the effect is the same. They allow you to alter the ride height of your car by compressing (or uncompressing) the springs. Some people think that adding spacers makes the shock stiffer, but this isn't really true. Shock stiffness is determined more by shock oil and piston choice. A lot of people setup their cars, using collars or threaded bodies, so the lower suspension arms are level.
Banned
RE: Shock spacers
Not true.
A lot of people that run threaded shocks use the spacers so they can equally wind the lock rings into place. They then leave them there to prevent the nut from moving as in your pic. The Idea of preloading the spring doesnt increase the rate of the spring (so your thinking is correct there) but to help set the ride height of the chassis. Normally though if your running over 15mm of spacers then your oil wt or qty is wrong.
Banned
RE: Shock spacers
6 of one ........ If you only have one set of springs, then they can't be wrong. I should've said the oil wt doesn't match the springs rating.
RE: Shock spacers
All my shocks in the swift came with these, I guess i don't really need them. Do you think kyosho blue springs will be good for this car? what difference will they make? (many people says the swift's springs are too soft.)
Banned
RE: Shock spacers
It all depends on which surface you are running on. Bumpy, then you want soft, Mild then Blue will be good and Hard smooth clay then white may be better. Then there's the oil wts aswell low for the bumpy stuff and hard for the big air and level sufaces. But if you want to get the Blue springs then I'd go with something around 25wt. It's all a preference thing.
