RC 1/8th Scale Buggies Discuss the ever popular category of 1/8th scale rc buggies in this forum!
Throttle Quest..
Old 03-26-2005, 06:46 PM
Dominic616
Default Throttle Quest..
I am just breaking in my new hyper 8 port .21 engine, and whenever I use any throttle, the servos move, but the car just stays in neutral. Any ideas as to why this is or how I can fix it? Thanks
Old 03-26-2005, 07:07 PM
danremote14
Default RE: Throttle Quest..
check out ur throttle linkage
Old 03-27-2005, 04:15 AM
casper7
casper7's Avatar
A silly point but, I had my engine out, put it all back together and forgot to attach the throttle arm to the carb, same thing happened. Also if the you have too much travel on the throttle arm, ie end stop collar too up the linkage it will all move but not open the carb.
Its the silly little things that prevent me running[&o]
Mike
Old 03-28-2005, 05:12 AM
Foxy
Foxy's Avatar
Maybe I misunderstood, but it sounds like a clutch issue to me?? If you mean that the servos move and the engine revs, but the car doesn't move, it just stands there, try re-adjusting the clutch.
