RC 1/8th Scale Buggies Discuss the ever popular category of 1/8th scale rc buggies in this forum!
OS RG .21???
Old 10-17-2005, 06:23 PM
JEXTEL
JEXTEL's Avatar
Default OS RG .21???
Im getting this in engine in afew days and the only pipe I got for it is the HPI ribbed pipe for low-end power...I ran this pipe with my hyper 8 port and it ran like it was a new engine..I was wondering would i gotthe same results with this engine and the pipe? also its a OS and I LOVE os engine the CV and CV-R i had for mt 1/10's were fansatic easy to tune and great engine life at 6-7 gals and still running...so would I have the same results? I cant wait to finish out this season..I LOVE THE 1/8 BUGGY CLASS...WoOt wOoT
Old 10-17-2005, 07:24 PM
MBX5T Maniac
My Feedback: (-1)
MBX5T Maniac's Avatar
Default RE: OS RG .21???
i've heard that the jammin jp-2 pipe is good with it.
just what i've heard though. absolutely no experience
Old 10-17-2005, 08:09 PM
JEXTEL
JEXTEL's Avatar
and I heard the jp-1 pipe was good..but I dont have that kind of money right now..
Old 10-17-2005, 08:27 PM
PATchy
PATchy's Avatar
i run an os rg with the jp-1 and it freakin rips dude, in my opinion, its the best pipe out for the rg, i heard the os 2050 works well with the rg too
Old 10-17-2005, 11:29 PM
J_Bone
J_Bone's Avatar
I run a JP-1 pipe with mine, but the JP-2 will give the Top end lacking RG more top end. IT will sacrafic some bottom end, but the RG has more than enough thta it won't be missed.
Old 10-18-2005, 08:59 AM
plaidfish
hands down best pipe fopr it is the OFNA .063 and run a 14t CB on it....1.0 springs and carbon shoes....it will snatch the wheels and GO.....
Old 10-18-2005, 05:04 PM
kx250ryder
kx250ryder's Avatar
ORIGINAL: plaidfish
What he said, except use mugen aluminum shoes, and maybe a JP-2 if you are running on longer straights. JP-1 or .063 on shorter straights.
Old 10-18-2005, 05:33 PM
J_Bone
J_Bone's Avatar
I don't think I would want to run Aluminum shoes with a 14T clutch bell? Grab too much??
The Jammin JP2 is the best IMO. It has the bottom end of a 053 and the mid and top end like a 086. All with a crush resistant stinger...Works very well on any high torque engine like the RG.
Old 10-19-2005, 09:38 AM
plaidfish
w/ a 14t CB I found I got better top end w/ the JP-1 and it got there faster too...the only place I saw better to pend w/ the JP-2 was on a 15t CB, but it was like getting a dog sled team started....took forever to get going and I even used 1.1 springs w/ aluminum shoes....it was still a dog......I did try all the combos I had of Clutch setup and pipe on my engines.....maybe I got too into the whole process but it was a great learning experience and I got to see first hand what th effects of different pipes and CLutch setups actually do....using the RG as the only controlled part of the process...
Old 10-19-2005, 05:40 PM
JEXTEL
JEXTEL's Avatar
get info guys but about the HPI ribbed pipe? lol think it willwork well from the tips you guys gave me it such be perfect..
Old 10-21-2005, 12:12 PM
peterman9000
i think os recommends the 2030
Old 10-21-2005, 12:31 PM
plaidfish
try the Ofna .063 w/ it..that's a nice combo...it's maybe 20 bucks less than a JP-1 and has a similar power curve.....
Old 10-21-2005, 03:58 PM
J_Bone
J_Bone's Avatar
ORIGINAL: plaidfish
For the RG, I would recommend the 086 or JP-2 over the 063.
Old 10-22-2005, 07:39 AM
plaidfish
different strokes for different folks.....
Old 10-22-2005, 08:08 AM
Haulin bass
Ive been told a true Rb o86 pipe is the way to go, but why spend as much on a pipe as an engine?
Old 10-22-2005, 11:57 AM
RCDadChicago
My Feedback: (34)
RCDadChicago's Avatar
So would the OS 21 be a better engine than the Force 26 or even the HPI .28?
Old 10-22-2005, 12:21 PM
PATchy
PATchy's Avatar
hands down to the os rg, its way better than the force 26 and hpi 28
the rg is the most reliable, easy tuning, engine i've ever had, its also the cheapest
you won't be sorry
Old 10-22-2005, 01:28 PM
SManMTB
SManMTB's Avatar
Can't go wrong with it really.
Old 10-22-2005, 02:09 PM
burnt3d
how does it compare to the new novarossi raul micron? i had a rg and broke the connectin rod. i dont think i had it broken-in properly. also, why cant you go WOT on the starter box? thats how i broke the connecting rod. ive done this serveral times with my mach 26 and no problems. Tim
Old 10-22-2005, 03:28 PM
kx250ryder
kx250ryder's Avatar
ORIGINAL: burnt3d
The Ral Micron line of Novarossi, is their attempt to make bargain engines. It is not a special model, just a cheaper one. Much like OS has the $300.00 V-Spec, and the affordable, less powerful RG.
When you go wide open on the ground, there is tons of resistance keeping the motor from revving too high. The air resistance slowing the car down, the rolling resistance of the tires against the road, and the force of inertia, which is trying to keep the car from moving. When you prop your car up on a stand, and run it wide open, there is no resistance keeping the engine from over revving, and spinning itself to pieces. I must ask, why did you feel the need to run the car wide open on the starter box? I find it rare (if at all) when I ever run my engine wide open, under any circumstance. These engines can spin 30k-40k RPMs, or 500+ times PER SECOND. Just imagine what kind of forces are going on inside that engine to allow that.
Old 10-22-2005, 03:33 PM
Engrose
Not to mention that when the car is stationary, the cooling is much less.
Old 10-22-2005, 03:35 PM
J_Bone
J_Bone's Avatar
ORIGINAL: Haulin bass
That is just like the OFNA 086, but OFNA is cheaper.
I have used the JP-1, JP-2 and 086 pipes with the RG. The RG has tons of bottom end already. The 086 and JP-2 are top end pipes and allw the RG to rev out a bit more.
I own and run the JP-1 on my RG right now. After testing my buddies JP-2 on it, I'm gettng one for it!!
Old 10-22-2005, 03:39 PM
Engrose
Did you notice a temperature difference between running with the JP-2 instead of the JP-1?
Old 10-22-2005, 03:41 PM
plaidfish
What gearing and clutch setup did you run?
Old 10-22-2005, 03:51 PM
J_Bone
J_Bone's Avatar
ORIGINAL: Engrose
I didn't notice a big spike in temp. Maybe 5F degrees, if that.
I'm running 30% O Donnell's and it was running good against some other P5's and 421's.
ORIGINAL: plaidfish
Stock, 13/46
