biggest
CA
biggest
hey guys. i got my buggy today. it looks to be an ofna 1/8 ultra mbx rtr. Anyways, this thing is friggin HUGE, seems to be bigger then my friends t-maxx. I was wondering whats the biggest engine you could put in this thing without doing any modifications.
thanks.
thanks.
RE: biggest
You can put a .32 in there (by collari) if you want, without eating the drivetrain or anything like that, but the competition class .21 engines are much better (but more expensive). Some important questions for you:
1) Are you bashing or racing?
2) How much do you want to spend on an engine?
3) Have you put a decent steering servo in yet? (Stock ones are absolute rubbish)
4) Have you bought a proper 6v receiver battery yet? (These things make a huge difference to the speed and response of the electronics)
5) Have you filled the diffs with appropriate weights of silicone?
6) Have you bought a decent toolkit (hex drivers, good ones).
If the answer to questions 3, 4, 5, or 6 is 'no' then do these things first, then consider an engine.
RE: biggest
ORIGINAL: thopper
If you wantto SCREAM put a NovaRossi .28 8 port in it. Price is about 300.00 It is the fastest engine out there.Period
Why is it the fastest?
it will make my buggy faster even if I have 12/55 primary gearing???
what about the specs on it?
I'm really not doing this post out of spite, but stating it's the fastest w/ no reasons is like screwing air......it's pointless......besides My Fantom .27 in a truggy smoked guys running those big rossis in truggies as well....depends on your track and gearing for what ENGINE is fastest....
QC, CANADA
RE: biggest
Yup,
What he said.
What he said.
ORIGINAL: plaidfish
I'll be the dick and play devil's advocate here....
ORIGINAL: thopper
CA
RE: biggest
I'm gonna be going for bashing. I was just wondering what would be the biggest engine I could fit Can I put a pullstart engine in the Ultra MBX?
VA
RE: biggest
ORIGINAL: foxy42
Sense your just bashing the collari .32 seems like the best motor for you but I don't know the price on it.
For the flywheel question... It depenends on how tall your motor mounts are. I honestly don't know how tall the mounts are on the MBX. Just get whatever makes the flywheel set just a tiny bit higher than the bottom of the chassis so it doesn't hit the ground if you bottom out and cut off the motor.
RE: biggest
ina buggy you want High RPMs not low end grunt.....look at teh sirio .27 if you really want to just kill speed and torque..it's pricey but give everything you need...also DO NOT get the 11 port model if you are not a super tuning guru.......the sleeve looks like swiss cheese and does not like to overheat...I've seen them literally warp while running and just destroy the mill...the 8 port is more than enough......if budget is a concern look athe wasp .28....about 160 new and it revs like a rossi 421b......but less than 1/2 the cost.....the fantom .27 is by far the meanest mill I ran in my buggy but the last one I got was such a lemon I just gave up on them, besides it's iffy as to whether he's going to do nitro engines for a while......I have a brand new .27 and the case is bored out too big...it let the sleeve chatter, that's bad...nothing holds the pinch on it now.....
RE: biggest
ORIGINAL: plaidfish
CA
RE: biggest
but i read that the team orion engines always have air leaks in them. and what about the starter box, the flywheels 2mm into the chassis, is that enough for the starter box to reach it? thanks, keep the posts coming.
RE: biggest
ORIGINAL: foxy42
Sure you didn't mean the other way around? On road wants RPM, off road wants grunt. Depends entirely what you're doing of course, but the extra weight of buggies has an automatic requirement for a little more torque, not to mention additional surface friction from off road (bumps, etc).
ORIGINAL: plaidfish
CA
RE: biggest
anyways, since im new to buggies, i have a couple questions; When do I have to apply differential oil, and what weight is good for bashing? whats a good weight for shock oil, and what is a servo saver used for?
RE: biggest
ORIGINAL: RcSuCkA
CA
RE: biggest
oh good thing i have a servo saver, lol. i was wondering why it said (indirect) on my steering servo but now i know why. thanks for the great info plaidfish.
anybody know if the hyper 7 starter box will work on the ultra mbx?
RE: biggest
when you get into higher end RCs the servo saver is actually part of the Steering linkage.....so the plastic ones you have now won't be needed......
