Official Thread for the Go 21 Engine
#726
MI
RE: Official Thread for the Go 21 Engine
ORIGINAL: gbasile77
Hi. I managed to get the carb off, however now with it all back in place the carb turns quite easily even though I have tightened the pinch bolt as much as is possible. This can't be normal can it?
Also, when the car is running on the box with the throttle in neutral position the revs keep rising quite a bit all by themselves. If I put the brakes on the revs go back down. What could cause this?
My throttle linkages and radio I believe are all ok.
thanks.
thanks.
#727
PA
Hey guys ....i have both, the 5 and 7 port. the 5 port carb seems jammed, it wont go wide open only about half ....like sometings in there .....any help out there ???????[]
#728
CA
ORIGINAL: kaptain crash
#730
CA
ORIGINAL: vyt666
here's my go 5-port
here's my go 5-port
#731
PA
Hey, tree1 thanks but the motor is off the buggy and cant move the the throttle body or slide past half way ... like something in there ...guess i have to tear down ...o well thanks guys
#733
CA
#734
ok guys and ladies how are ya..i just got a A .28 GO .im looking to get parts for this thing any help in where thanx
#735
http://www.amainhobbies.com/index.ph...Tech-28-6-Port
If you need anything else lmk. im friends with a guy who is a dealer. Im sure he can get you hooked up with some stuff=)
