New motor break in-ur thoughts
About to drop in the os vzb v-spec into my sp2 and really want to do a good job breaking it in. Ive scoured the internet for different advice and I think im going to us the "heat-cycle" method as suggested by an rcu review. Anyone tried this? Would anyone recommend using a break in fuel, e.g. by trinity, or just use what i plan on running for racing? Just want to get max potential and use out of this motor, everything ive read says its awesome. Thanks.
IN
RE: New motor break in-ur thoughts
Heat cycle is great.
No do not use break in fuel use what you are planning to run. If decide to change fuel in the future, you will need to re-break in the motor.
remember to heat your motor each time before turning it over to save the con-rod
Banned
Heat cycle kills V-specs. Too many people who have done it have complained about premature deaths on this forum. I prefer the 6 tank method and both of mine are over 15 gallons and snag free.
FL
Just heat it up with a heat gun or hair dryer before trying to start it. Keep the temps over 200 F and rev it a little more each tank. It's not rocket science, just don't push it too hard for a while and it'll break in real nice.
ORIGINAL: livthemoment
ORIGINAL: annie_himself
You just will need to make minor adjustments not re-break-in.
agreed, i just changed my mach .28 from 20% fuel to 25%, when i finished the 20% i turned my high speed needle 1 full turn richer, then ran 3 tanks at that setting, and then tuned it again, wasnt hard and its running sweeter than ever!
ND
The best advice for breaking in a new engine comes from the instruction manual. I’m not saying this is the easiest way but when you have problems or screw up your new engine and you followed the instructions you don’t break warranty. BTW they have a good idea about a good way to break in their engines.
Follow the manual, unless you are very expeirenced at breaking in engines /tuning.
90% of the time following the break in method suggested by the manual will be the best option.
If heat cycle shortens v-specs life im sure it will give you a different method other than heat cycle in the manual.
Id follow the manual if you dont know what your doing at least that way your covered by the warranty. Engine manufacturers actually do research on their engine not just preffer some random way of breaking in. Theres been a big war on breaking in your engine since theres sooo many ways you can do it
My preffered way is sort of like the heat cycle method except i let it warm up first for at least 2-3mins before putting it on the ground and start throttling. I do this because most engine manufacturers will recommend you too get your engine to running temps before doing anything at least that way your engine internals have expanded.
Doing the exact heat cycle method which is plopping the car straight away on the ground and throttling doesnt exactly give a cold engine a good time. Its just my way, theres alot of other ways that works but i still have great compression after 5months+
