o.s rg?
RE: o.s rg?
we have a couple of guys at our track running the VG right now. They seem to be very good motors run like a top plenty of power. Great bottom end. Laking a little on the top but they do a great job.
ORIGINAL: R/C biy
really does that motor have good power and keep its tune very well?
GA
RE: o.s rg?
VG has ABL sleeve and the verdict is still out on it. OS is the only one using it and even on their high end engines are using ABC like 99% of the other engine manufactures. If you get the OS VG please give us an up date when you have at least 5 or 6 gallons on it.
RE: o.s rg?
I blew the rear bearing after 2.5/3 gallons, but man was that motor nice. plenty of power for short tracks. I run the werks b3 right now and wish i had another vg. Just replace the rear bearing before too much wear. The motor breaks in easy enough, holds a tune well, and I think my issue was related more to the fuel i was running ( mixed locally) and/or just a bad bearing.
TX
RE: o.s rg?
Got about 2 gallons through my VG. Can't complain other than the long break-in process. Ran about 1/2 a gallon through it before I felt comfortable putting to the track to race..............
Banned
RE: o.s rg?
nothin compares to it. im runnin a RG in my X5. and i will run it forever. i rebuilt it once and i will continue to rebuild it when its needed. before my last rebuild i had a good 17 gallons on it. untill the piston and sleeve was so worn out i was loosin compresion. as long as the parts are available for the rg i will i will never use a different motor. its to bad they dont make em anymore but its cool theres still all the parts for them
