tire recommendations
MI
Whats a good tire to go with on my 1/8 scale buggy?
The track has a few short grass sections, some hard packed sand clay mixture sections and some loose dry dirt in some corners in other sections.
The best thing to do is ask the fastest racers at the track what tires they use. That will give you the best selection of tires to choose from that you know will work at your track.
www.focusprinting.com
TN
seriously, when he said it had some hard packed stuff i was gonna say, holeshots, or inside jobs, then i read the grass, and the loose corners, i'm like [&:]
MN
Panther K2's in Med-Soft are a great all around tire that will work well in everything but a sand pit. But really, talk to some of the other racers and find out what they are running. That will give you the best idea.
