Regrets - Help?
Regrets - Help?
Hey all. Before I knew too much about rc cars i bought a 1/8 Matrix C-1 RTR. now i regret it and should have bought the matrix cen kit! anyways, its too late now. is it possible to upgrade my c-1 rtr or a cen?
also, my friend has a 8ight rtr. as far as rtr go, is that a better car?
thank you.
thank you.
RE: Regrets - Help?
What's wrong with the RTR? All you really need to upgrade for club racing is the motor (to a decent .21), the front steering hubs (the machined ones are much better than the cast ones), the front steering knuckles (the Firoini mp777 knuckles give you more steering throw than the Cen machined knuckles but they are both much better than the cast ones), and the cross pin kit for the diffs if your rtr did not come with them (the new kits and rtr's come with the cross pin diffs now). A faster steering servo would also be a great upgrade. You can upgrade the shock towers, but I would leave the stock ones on and upgrade them if they got damaged. Besides that, I would work on setting it up and practice driving. You can upgrade the C-1 to a full FTE version, but most of the upgrade parts won't matter until you get really good (plus it will be very expensive to do that). Just my 2 cents. [8D]
www.focusprinting.com
GA
RE: Regrets - Help?
first off its a rtr it not going to be top notch and the cen cars are very good i drove a matrix pro for a year are better just change the front nuckles out and get the crosspins for the diffs and the car will be fine and i dont think it is any better are worse than a losi rtr but it probley alot tougher.
RE: Regrets - Help?
[quote]ORIGINAL: MatrixC1
thats funny i did the same thing but with a hyper8!
its pretty close to a prokit now . i've also decided to buy a pro kit this fall and build it over the winter. and use that for next racing season and use the rtr i have now as a backup and light basher
FL
RE: Regrets - Help?
my bro has a matrix rtr and the cen .26 SCREAMS!!!! it will make his buggies pull wheelies and the tires ballon up!! im dead serious
this happens when he can get the engine to run
half the time his wont run
