Is my engine a Pro 21 Turbo
I recently brought a Thunder Tiger Pro 21 off ebay and he listed it as a turbo
It was a bargain £27
Can anyone tell by looking at the engine bellow if it is a turbo
RE: Is my engine a Pro 21 Turbo
ORIGINAL: adam-69
is that not a hobao .21?
He did list it as Hobao Hyper 21 Turbo Engine
and is fitted with a McCoy MC-9 glo plug
I have not got the engine yet should get it tomorrow or friday
Unless the guy is referring to an actual "turbo" fan attached the pull-start mechanism. A buddy has a Hyper (Hobao) .21 and it had little fins on the the spin-start mechanism or on the back of the crank that looked just like a turbo fan.
There appears to be some confusion over the term Turbo here.
K B is pointing to a turbo plug engine, which in most terms IS what a turbo engine is reffered to.
In this case though the hobao engines refer to a turbo engine as one fitted with a little fan on the crankshaft. This fan disperses fuel more efficiently for combustion.
So to answer you question Bry, yes it is a hyper .21 turbo, but it is not a turbo plugged engine.
Hope that clears it up
[link=http://www.rcteam.no/images/sprengskisser/mach-21_sprengskisse.pdf]For information[/link]
part 21021 is the 'turbo' fan in quesion
PA
Ok you are all correct. But OFNA does makes an actual "TURBO" style engine. The backplate of the engine has a turbofan style design, its meant to put more air nitro mixtures into the engine, however that engine does not use a TURBO plug..
There are some engines like for instance the OS.21 VZ serioes they have a bump start back plate but require a turbo plug.
ORIGINAL: jonnymac
I have seen them before and wondered how they are fitted.
By looking at the picture it needs a good clean, so i will strip it down and rebuild it.
Thank you
VA
ORIGINAL: nitro bry
ORIGINAL: adam-69
Why do you say you got a Thunder Tiger when the guy said it was a Hyper 21?
[sm=confused.gif]
ORIGINAL: SManMTB
[sm=confused.gif]
ORIGINAL: nitro bry
ORIGINAL: adam-69
[sm=confused.gif]
I sent him an email and he came back with a Thunder Tiger
