dynamite .21 mach 2
KS
RE: dynamite .21 mach 2
ORIGINAL: NORCALLUMP
is this the same engine as the sportwerks .21 v2?
Specs
* Displacement:.21 cu in
* Bore:16.3mm
* Stroke:16.8mm
* Engine (Only) Weight:371g
* RPM Range:34,000
* HP:2.5
Dynamite .21 Mach 2
Specs
* Bore:16.27mm
* Stroke:16.75mm
* Engine (Only) Weight:310 g
* RPM Range:up to 33,000
* HP:2.3
