Hyper 7 or Picco? Which is best choice
Right now I'm currently a Jato owner and looking to get into 4WD 1/8th buggy scene. I would stay with traxxas if they would release a buggy but doesn't look like they are anytime soon so sellin the jato and lookin for moderately priced buggy. Just wondering if I should get the hyper 7 or the picco? Which of the two is newer and which of the two would be the best bet when it comes down to duribility, performance, and reliability. I plan on upgrading the radio system as soon as i get either of these with a faast system and 2 new servos.
Overall
Which of the two would be best choice?
How much could I get for the stock radio system/servos brand new?
Anyone interested in a jato? Comes with 3.3 1/2 gal and a OS .18tm just broken in!! rare engine.
Thanks!
Overall
Thanks!
the picco all the way. its better than the hyper 7 in every way possible. it comes with the same shocks that comes on all the Jammins now. the picco is pretty much an updated version of the hyper 7 and the 9.5 violator, it also has some things from the jammin X1. it is the best bang for your buck when it comes to RTRs IMO.
Neither, save some money and build a kit. You will be much happier and spend less
money in the long run. As far as a RTR goes the losi is a better choice as is the
Jammin X1. If you want my opinion the Jammin is the ONLY Hong Nor I would
ever consider. The Picco is not an updated Hyper, they come from two totally
different companys. The Hypers are made by HoBao. Either buggy is several generations
old and based on heavier outdated chassis.
Location: San Diego but living in Dubai, UNITED ARAB EMIRATE
ORIGINAL: JsK
picco. i just got one a couple weeks ago and it rips. unless ur gona be racing at a national level its not worth it to spend all that money. imo
Found this video today, thought it was quite halarious, considering the picco took it off the line but thats besides the point. This race track is like bumper cars cause it's some crazy hard grass with moss or something. Anyway handles pretty good but not much to say about these drivers...http://www.youtube.com/watch?v=WztQz...eature=related
WA
ORIGINAL: JsK
CA
it depends on how much you want to spend really but i got my self the jammin X1 CR( 1st buggy ) and i upgraded the servos and radio and love it man the only thing that sucks is if you race in big races then your going to have to buy a .21 but if you just do club races, practice or bash around then you'll be fine with the .28 is has, as far as durability it seems to hold up well and i gota say i flipped and tumbled a few times and hasn't broke yet, but i asked the same thing when i first started the buggy's and it seems the picco would be best choice, but if you want to spend a little more but not to to much then i would get a jammin if you want a RTR, im new at the buggy thing but i hope this helps a bit
MO
i have purchased them both ways, the best thing about a RTR is you can run it the same day you purchase it,,upgrade as you go,,i can't say the kit was really any cheaper,,in this hobby it's never ending,,you always want to upgrade parts when there is something new
I bought my picco buggy last night.
- 120$
$514.91. Not too bad considering I'm getting new radio and 2 new servos right off the bat. I just have a question about break in. What method do you guys find the best for these? And How do you think i made out price wise, all in all. Thanks!
Ofna 1/8 Picco Off-Road Nitro Buggy RTR | 1 | 319.99 |
Hitec HS-5645MG Digital High Torque Metal Gear BB Servo | 2 | 109.98 | ||
Futaba 8-Cell 9.6V 700mAh NiCd Transmitter J 3PK | 1 | 34.99 | ||
Futaba 3PM-X 3-Channel 2.4GHz FASST Tx/R603FF Rx | 1 | 169.95 |
- 120$
where did you purchase them ? that just looks high, the picco on amain is 289 i think and those servos cost 35 bucks a piece so that seems high but not to high. you still did good on your buy. and on break-in run it really rich but just lean enough so it idles, and idel it threw atleast 5-6 tanks and then just do figure 8s in the road and leave it rich and just give it about half throttle, always worked for me. no wide open throttle for atleast half gallon.
Got off tower. Got free shipping too on everything so. I don't know it was 514 after everything? Not too bad considering idk. Cause 319-60=289.99+ the other stuff so.
TX
Don't idle 5 tanks through it!!!!
Get some foil and wrap the head, heat it with a hair dryer or heat gun to 190-200 and start it. It is hard to keep it warm running it rich, so use tin foil and check the temp all the time. Idle one tank... you may need to SLIGHTLY tap the throttle to get it to stay running the first tank. First tank sucks usually.
Now drive it 4 or 5 tanks VERY slow. Using foil and a temp gauge to keep it up around 190-200. Let the temp cool to <100 between tanks.
Now most people would say to start leaning it out and tuning it..... I say lean a little and run 1/2 gallon easy on it, with hardly any full throttle. I do mine at the track and just do boring laps and no big air. And letting it cool between each tank.
OS break-in said to do idle it threw 5 tanks, and everyone i race with does the same thing......
but i did forget about heating it up before you start it.
UPS is saying I'm supposed to get in tomorrow so hopefully, and take some pics for you guys! Don't know if I'll be starting break in tomorrow though, maybe this weekend.
i'm probably to late ,ofna tells you to mess with the needles out of the box.do not and i quote "do not touch the needles yet.break it in with the needles at factory settings please.ofna does not make that engine they make the car only.picco makes the engine with that kit you will find a small booklet from picco that tells you te engine is already set at factory settings that is how you should break it in. i owned this car and made the huge mistake and reading the ofna instructions.
Getta rip out the reciever/servos etc.
Anyone got price advice for selling the stock system brand new? Transmitter/Reciever/2x servos?
IL
PICCO [sm=thumbs_up.gif]
your not going to fetch much, figure $45 or so. i say keep the system aside if you want to build a basher later on.
#1 Start, neglected to re-check my throttle servo after messing with my radio
http://s76.photobucket.com/albums/j1...ent=001-14.flv
