Need more top end
My Feedback: (34)
Need more top end
I have an Ofna Comp lx with the original .28 engine. My question is how can I get some more speed on the top end. Someone told me I could change the gearing but I'm not sure what gearing they are referring to since it could be at several different points. Any suggestions?
RE: Need more top end
more teeth on the clutch bell, i think it comes with a 13 tooth clutch bell so you can get a 15 tooth clutch bell but it will take away from the bottom. also you can get an top end pipe for example the Dynamite 086 pipe will work great. very durable and gives it a good bit more top end.
hope this helps a little.
My Feedback: (34)
ORIGINAL: jmaxey51
Does Ofna make a 15 tooth clutch bell or are most of them universal so I can buy any manufacturer?
MA
Easiest way? Get a taller clutch bell.
Best way? Get a nice engine with a lot of ports... like the Go tech 28R 6+2 port.
It happens to be on sale at A main:
http://www.amainhobbies.com/product_...-Standard-Plug
Specs here:
http://www.go-engine.com/in-products...86P-P420SG.htm
Specs here:
NC
ads8525, well how it going neighbor. good to see a local on here. I live in Kings Mtn. not very far from Charlotte. Any good tracks your way?
Location: San Diego but living in Dubai, UNITED ARAB EMIRATE
ORIGINAL: ads8525
ORIGINAL: jmaxey51
http://www.amainhobbies.com/product_...gen-OFNA-Style
My Feedback: (34)
ORIGINAL: big_poppa49
My Feedback: (34)
ORIGINAL: tommygun32
On Special for 8.25
ORIGINAL: ads8525
ORIGINAL: jmaxey51
I'm not sure how much more speed you'll get up top honestly. If memory serves me correctly, I think I tried to put a 16 tooth cb against the stock spur gear (48 tooth I think). That was too much of a jump and the teeth wouldn't mesh. I would have had to change the spur gear. Didn't bother.
It probably wont be that much of a jump. And as was mentioned previously, your bottom end will end up suffering a bit. It all depends on the size of the track you're running and what you're looking for. If you can, try and go head to head with your buddies who are running different cb's and do a comparison.
It also depends on the performance of your engine (which I have no experience with), pipe, clutch, diff oils, etc....they all work in conjunction with eachother
Good luck.
Good luck.
just know when changing the teeth is will effect the bottom alot. even going from a 13t to an 14t CB will make the bottom alot less snappy.
NC
Yes, as a matter of fact there is a very nice track in Cherryville, only about 25 min from my house. They have races every sunday and occasionally have a big race, about 4 big races a year. I have heard of the track at hobby stop. I believe the place you were talking about may be the indoor track at Carolinas RC, I think they are re-locating to a better location.
My Feedback: (27)
put a gps on the back of the car and see what your real top end is now with the 13T CB and then compare with a 15T CB. I did this with my hyper 7 and with the stock 13T bell and the stock .21 engine the top end was about 35MPH with a 15T CB it was a 40MPH so 2 teeth on the CB should give you about 5 MPH over what you have now.
NS, CANADA
Assuming the engine can attain the same rpm with the higher tooth bell, increase in road speed is the ratio of the new to old CBs. For example, going to a 15 from a 13 gives you an increase of 15.38%. So if you were doing 40 mph, you will now do 46.15 mph. As the engine will be more loaded at this higher speed, you may not quite achieve 46 mph, however the ballooning effect from the tires may compensate somewhat. As above, getting 45 mph from the change seems likely.
You will also lose low-end torque, so going up to a 15 might be good for tracks with long straight sections, however for short straights with lots of corners, you would probably be faster around the course by sticking with the 13 tooth CB.
I think most CBs are interchangeable between brands as long as they are all for a big block crankshaft. Most big blocks seem to take the 5x10x4 bearings, so you might be able to tell that way.
ORIGINAL: supertib
Buy a faster engine ! gearing up is not the answer...you need an engine with a better top end !
