RCU Forums
-   RC 1/8th Scale Buggies (https://www.rcuniverse.com/forum/rc-1-8th-scale-buggies-244/)
-   -   Help!!!! MBX6 steering problem (https://www.rcuniverse.com/forum/rc-1-8th-scale-buggies-244/10643491-help-mbx6-steering-problem.html)
DJGray17 07-28-2011 11:35 AM
1 Attachment(s)
<span class="Apple-style-span" style="font-family: arial, sans-serif; font-size: medium; "><table class="Bs nH iY" cellpadding="0" style="position: relative; -webkit-border-horizontal-spacing: 0px; -webkit-border-vertical-spacing: 0px; padding-top: 0px; padding-right: 0px; padding-bottom: 0px; padding-left: 0px; border-collapse: collapse; background-image: initial; background-attachment: initial; background-origin: initial; background-clip: initial; background-color: rgb(255, 255, 255); width: 1053px; background-position: initial initial; background-repeat: initial initial; "> <tbody> <tr> <td class="Bu" style="margin-top: 0px; margin-right: 0px; margin-bottom: 0px; margin-left: 0px; font-family: arial, sans-serif; vertical-align: top; padding-top: 0px; padding-right: 0px; padding-bottom: 0px; padding-left: 0px; "> <div class="nH if" style="padding-top: 0px; padding-right: 0px; padding-bottom: 1px; padding-left: 0px; "> <div class="nH"> <div class="nH hx" style="color: rgb(0, 0, 0); padding-top: 4px; padding-right: 8px; padding-bottom: 4px; padding-left: 8px; "> <div class="nH"> <div class="h7 ie nH oy8Mbf" style="clear: both; padding-bottom: 0px; "> <div class="Bk" style="position: relative; margin-bottom: 10px; border-right-width: 1px; border-bottom-width: 1px; border-left-width: 1px; border-top-style: solid; border-right-style: solid; border-bottom-style: solid; border-left-style: solid; border-top-color: rgb(239, 239, 239); border-right-color: rgb(239, 239, 239); border-left-color: rgb(239, 239, 239); border-bottom-color: rgb(226, 226, 226); border-top-width: 0px; border-top-left-radius: 7px 7px; border-top-right-radius: 7px 7px; border-bottom-right-radius: 7px 7px; border-bottom-left-radius: 7px 7px; width: 804px; "> <div class="G3 G2" style="padding-top: 3px; background-color: rgb(255, 255, 255); border-right-width: 1px; border-bottom-width: 1px; border-left-width: 1px; border-right-style: solid; border-bottom-style: solid; border-left-style: solid; border-right-color: rgb(188, 188, 188); border-bottom-color: rgb(188, 188, 188); border-left-color: rgb(188, 188, 188); border-top-width: 1px; border-top-style: solid; border-top-color: rgb(188, 188, 188); border-top-left-radius: 7px 7px; border-top-right-radius: 7px 7px; border-bottom-right-radius: 7px 7px; border-bottom-left-radius: 7px 7px; "> <div> <div id=":ch"> <div class="HprMsc"> <div class="gs"> <div id=":cj" class="ii gt" style="font-size: 13px; margin-top: 5px; margin-right: 15px; margin-bottom: 5px; margin-left: 15px; padding-bottom: 20px; position: relative; z-index: 2; "> <div id=":ci"><span style="font-family: Helvetica; font-size: medium; ">Hi I just recently built a mbx6 kit and my problem is the steering. for some reason my rod touches my upper arm, and when i turn all the way the right or left my left tire does not move it drags. here are my pictures. BTW this is my first Kit I have built.</span></div> </div> </div> </div> </div> </div> </div> </div> </div> </div> </div> </div> </div> </td> </tr> </tbody></table></span>
pigpen1 07-28-2011 02:16 PM
RE: Help!!!! MBX6 steering problem
what is your droop set to?
jmaxey51 07-28-2011 07:54 PM
ORIGINAL: pigpen1
droop wouldnt cause that, something else is weird. even taking droop screws out and shocks off, it will still not hit.
can we get a veiw from the front like both arms?<br type="_moz" />
DJGray17 07-28-2011 10:32 PM
1 Attachment(s)
I have contacted Mugen and sent them pictures and they told me that my kit came with the wrong arms. so they r sending me new ones.
MX250 07-29-2011 05:01 AM
go here for all your questinos & needs.:D
[link]http://www.rctech.net/forum/index.php[/link]
jmaxey51 07-29-2011 09:24 AM
ORIGINAL: DJGray17
i was thinking they might be MBX5 arms LOL. that should fix it... i know for a fact its not droop like people are posting on rctech.
<br type="_moz" />
DJGray17 07-29-2011 10:07 AM
I sent pictures to mugen and they told me they are the wrong arms. they r sending me new ones. heres my other problem.
http://www.youtube.com/watch?v=frak6NiOGV8
jmaxey51 07-29-2011 12:38 PM
ORIGINAL: DJGray17
did you put the set screws in the axels to the wheels? if so, take the set screws out, the bearings hold the pins in. you might also have your front brake to tight from the start.
<br type="_moz" />
meef rustler 07-29-2011 05:21 PM
ORIGINAL: MX250
Go Away!
DJGray17 08-04-2011 12:41 PM
What do you mean?
jmaxey51 08-04-2011 03:26 PM
the pin that holds the two pieces of the axel can have a set screw and if you put the set screw in it, when you turn it can bind and not let it role.
DJGray17 08-05-2011 03:02 AM
Hahaha. I had the pin in backwards.:D
