RCU Forums
-   RC 1/8th Scale Buggies (https://www.rcuniverse.com/forum/rc-1-8th-scale-buggies-244/)
-   -   Help with converting Pullstart to Rotostart (https://www.rcuniverse.com/forum/rc-1-8th-scale-buggies-244/11607644-help-converting-pullstart-rotostart.html)
mrjordan 12-07-2014 03:29 PM
Hey guys the images will make clearer what im about to say but here it goes
I recently purchased a Hobao Hyper 9 from an ebay seller ,all as well and everything worked apart from the pullstart which expanded,so i have to replace that but i want to replace it with a Rotostart,from looking at my engine i dont think i can do this but maybe you guys can tell me what i need to do to make this possible
Heres the images anyway, the engine is a .21 nitro
http://s1383.photobucket.com/user/jo...?sort=3&page=1
Anthoop 12-08-2014 01:00 PM
I can only guess that it is a Hyper.21 or Macstar.28 from the pictures?
If it is one of the above engines then there are roto bits that will fit... http://www.ebay.com/itm/Hobao-Hyper-...item48715a5a76
The .21 and .28 can both use this roto.
The pulley that you have in your hand in one of the pictures will need to be removed from the starter shaft (just pull it off)...put the starter shaft back into the engine backplate (will take some jiggling to line up the turbo fan/one way bearing)...then install the roto bevel gear and then housing.
