different engine mounting screws for mbx r2
the heads on the screws are not flush with the bottom of the chassis, they stick you quite a ways, are there any flathead screws that i could use instead??
RE: different engine mounting screws for mbx r2
these would work with the ofna engine mount correct??
http://www2.towerhobbies.com/cgi-bin...?&I=LXBZY2&P=7 |
| All times are GMT -8. The time now is 04:42 AM. |
