RCU Forums
-   RC 1/8th Scale Buggies (https://www.rcuniverse.com/forum/rc-1-8th-scale-buggies-244/)
-   -   Shocked Servos ! (https://www.rcuniverse.com/forum/rc-1-8th-scale-buggies-244/1367306-shocked-servos.html)
MassiveMods 12-21-2003 09:29 AM
Shocked Servos !
hey all
having trouble with my servos. i have a futaba MJ control unit and GWS servo S06/2BBMG ( hi torque ) . the problem is its going nuts . it malfunctions, revs by its self after turning and then just shuts down in full lock, ie wont respond till i turn it off and on again. its really strange because it happened gradually over a couple of weeks.
A what could be the problem? do i need to fine tune the unit or
B should i just get a whole new radio?
C what is a good reliable radio? ( money not a problem )
Aerobirdbrain 12-22-2003 02:26 AM
RE: Shocked Servos !
Well.....
A: GWS is ok fer airplanes, but fer cars, it's suicide!
B&C:All you really need to do is toss out those GWS servos and get some Airtronics or Hitec servos, but if the problem still persists, then yer reciever is toast. In that case, just get a new reciever. If you really want a new radio however, the radios to get are the Airtronics M8 FM or JR R1 PCM. The M8 is an excelent radio because of its reliability and all of the digital bells and whistles. The R1 has all of the same great features that the M8 has, but the R1 has a PCM modual.:D A PCM system basicly eliminates "same channel" interference because PCM over powers FM and AM modulation. So, in english, if someone on the same channel as you has an FM system and you have a PCM system, you will over-ride his radio and you will have control of both trucks rather than both of you going out of control.:D
MassiveMods 12-22-2003 02:41 AM
Hey AeeoBirdBrain (cool name btw )
sounds like a plan ! ill look into that . i might just ring my LHS and tell him to order me in one of those and take back the one he gave me. thanks for the advise bro !
:D
