RCU Forums
-   RC 1/8th Scale Buggies (https://www.rcuniverse.com/forum/rc-1-8th-scale-buggies-244/)
-   -   Tire problems (https://www.rcuniverse.com/forum/rc-1-8th-scale-buggies-244/1407105-tire-problems.html)
motard_man 01-06-2004 06:37 PM
Tire problems
Ok I super glue all round and the bliters came free. Then I got some industrial adisive and during a top speed powerslide the outer two under the most presure broke free[X(] diging my shiny new rims in to the tarmac:( causing a big flip[:@] (no damage done though)[8D]...I have never come against such a week way of fitting tires to wheels . Is this my buggy (phaser 4) or do all buggy tires prove a problem?? And can I get tiighter fitting ones to stop this..? What do you use to glue yours?
nitroman88 01-06-2004 08:23 PM
RE: Tire problems
try sanding your rims alittle, if they have paint on them the glue wont work too well. Also if you wanna do alot of slides then find a really hard insert.
FROGGY-RCU 01-09-2004 09:26 AM
RE: Tire problems
before glueing your wheels and tires clean them with denatured alcohol.the wheels and tires have a releasing agent on them so they will come out of the mold and glue doesn't like sticking to it.
studysession 01-09-2004 01:56 PM
RE: Tire problems
ORIGINAL: FROGGY-RCU
Great suggestion - but so far here in the UK where he is, I can not find denatured alcohol myself.
I know tha sanding does help. wipe away any loose particles with some cleaner of some kind. They should not come unglued that easily.
motard_man 01-09-2004 02:07 PM
RE: Tire problems
thanks people I will have a go at that soon cheers.;)
Rekker 01-09-2004 02:34 PM
RE: Tire problems
Studysession,
Denatured Alcohol is the same as Methylated Spirits which you should be able to lay your hands on at any DIY store.
As someone from the UK now living in Houston Texas, I run into the whole English - English language barrier thing on a regular basis.
gregmax 01-09-2004 02:44 PM
RE: Tire problems
You can also try acetone, or nail varnish remover or Tamiya Acrylic paint thinner.
studysession 01-09-2004 04:00 PM
RE: Tire problems
ORIGINAL: Rekker
Studysession,
I have found it and a few other good items. Thanks.
Which part of the UK are you from?
Fil 01-09-2004 04:47 PM
RE: Tire problems
Is it better to glue tires on wheels or to buy then ready glued?
Are the ready glued tougher? Do they come w/ foam inserts?
studysession 01-09-2004 04:53 PM
RE: Tire problems
Most ready glued have foam inserts. It is a prefrence to buy preglued or not.
fhm101 01-11-2004 01:16 AM
RE: Tire problems
If you buy preguled 8th buggy wheels, do yourself a favor and run another bead of CA around the joint on both sides. I've tried Medial Pro preglued and they were slinging off the rim. A quick zap of CA cured the problem. If the tread pattern you need is available pre glued, it's a no brainer.
