Gear Chart
Does there exist a gear chart that will show what will happen when changing the gear ratio?
Spur gear, clutch gear, etc... Also is there a chart of all the different batter, switch, receiver, servo plugs? I got a hump pack for my buggy and it does not properly plug into the stock switch. And where can I get a set of all the different plugs so I can do a switch on my hump pack so it will work with my on-off switch? Thanks |
RE: Gear Chart
basically, a smaller clutch gear and/or larger spur gear will increase acceleration, and larger clutch gear and/or smaller spur will give a higher top end
RE: Gear Chart
you could use excel and make one.
RE: Gear Chart
Thanks for replies.
I saw a chart in a pit box at a race once and I just thought that someone here might have one! I do not have nor know how to use excel! |
| All times are GMT -8. The time now is 02:43 AM. |
