Ofna Lx Pro comp
I like the buggy but hate the pull start. Does any one know what roto start will fit the .26 engine? I have been told it will work, but I know they make different versions. I want to order one from Tower and I need the part #. I dont want to go with a starter box because it is one more thing to charge and lug to the track. Also, will the .26 fit in a tmaxx 2.5 truck? I have been wanting to upgrade the motor in it, but I might upgrade the buggy if the .26 buggy motor will swap into the tmaxx.
Thanks for the help. Don |
RE: Ofna Lx Pro comp
No the .26 engine will not fit your tmaxx unless you get a .21 conversion kit, second yes you can get a roto start, ofna has one maybe you should check that out.
| All times are GMT -8. The time now is 12:29 PM. |
