K-FACTOR HUBS?
Does any one know where i can get these? i got a inferno that had them on it and a wheel nut stripped out. it is left handed threds. the hub is fine i just need the nuts they have a rubber o-ring in them.also where is a good place to get KYOSHO 7.5 parts? please send me a link if you can. THANKS GUYS!!!
RE: K-FACTOR HUBS?
Here's a lift from trinity's catalog.
Special Wheel Adapter (MP7.5) (2) KFactory Aluminum Special Wheel adapters for the Kyosho MP7.5. Quality machined wheel adapters to keep your wheels running true and eliminating unsprung weight at the same time. Two pieces to a bag. Their (trinity) P/N is shown as K8004 and you should be able to get them anywhere that stocks trinity parts. One thing to make sure of. There is a pic in the catalog showing 3 identical looking drive hexes each with a different colored nut, all marked "R" which I assume is for right. I know they come as a set of one left and one right, but they didn't list any different numbers for different colors. It might not hurt to verify with whoever you order from what color you are getting if that kind of thing matters to you. Hope this helps. |
RE: K-FACTOR HUBS?
thanks man -mine are blue and i will note that to them and yes they are stamped r-for right and L cool now i can get down to business...
RE: K-FACTOR HUBS?
www.rcmart.com has inferno parts. also try substiture hyper 7 parts for kyosho parts. thats what i did. work out cheaper. now i am using xb8 parts. even more cheaper :D
RE: K-FACTOR HUBS?
1 Attachment(s)
ORIGINAL: hyperpmp1 where is a good place to get KYOSHO 7.5 parts? please send me a link if you can. THANKS GUYS!!! http://www.mgm-racing.com/mp7.5.htm at mgm the shocktowers are tuff he garentees his stuff just ask him at harcore they make great titanium stuff at the gs site the team option stuff is second to none. at rcmart the JET and GPM aluminum stuff is great too Hope this helps here is my K3 hopped-up |
RE: K-FACTOR HUBS?
SWEEEET this helps me out a lot! i love this kyosho way better than the hyper. i took the center spider out already and put it in the 7.5. it has the kanai 2 chassis also. im going through it now and it is gonna fly. cant wait ...
RE: K-FACTOR HUBS?
u used the inferno chasis on the hyper7?
RE: K-FACTOR HUBS?
no i took the hyper spider diff and put it in the inferno
| All times are GMT -8. The time now is 07:31 PM. |
