RCU Forums
-   RC 1/8th Scale Buggies (https://www.rcuniverse.com/forum/rc-1-8th-scale-buggies-244/)
-   -   hyper 7pbs shock tower? (https://www.rcuniverse.com/forum/rc-1-8th-scale-buggies-244/2719967-hyper-7pbs-shock-tower.html)
speedywheels 03-02-2005 07:43 PM
does any shock tower(s) fit the the pbs ie hyper 7 pro or sport shocktowers. thanks again
nbt93uw 03-03-2005 01:38 PM
RE: hyper 7pbs shock tower?
You need to run the PBS shock tower. It is a little differnet then the regular C-hub version. Check out ebay for pictures of the PBS version. I recently bought the Ofna CNC PBS Shock tower for $15. It is much thicker then the original and well made.
casper7 03-03-2005 03:23 PM
1 Attachment(s)
You can run with the 6mm shock towers back and front from rc-badboy on ebay, the PBS difference relates to the hub carriers, i.e they are PBS an not C hub carriers. So no problems with the shock towers.
Mike
Da Smak 03-03-2005 04:01 PM
ORIGINAL: casper7
Mike
I think you'll find that the towers are different on the front of the PBS and c hub variants. That said you can still fit the c hub ones to a PBS ok, though you must use the upper hole for the top arms.
casper7 03-03-2005 04:04 PM
Yes that is how I fitted mine
Mike
