RCU Forums
-   RC 1/8th Scale Buggies (https://www.rcuniverse.com/forum/rc-1-8th-scale-buggies-244/)
-   -   hyper 7 engine (https://www.rcuniverse.com/forum/rc-1-8th-scale-buggies-244/2857620-hyper-7-engine.html)
Goaferboy 04-08-2005 05:22 PM
hyper 7 engine
iv got the hyper 7 tq sport with a 4 port engine. would i be able to put the 8 port straight in or will i need to upgrade some of the gears as well?
evilstoat 04-08-2005 07:28 PM
RE: hyper 7 engine
Hi should be fine to just put the engine straight in, changing the gears clutch bell(pinion) gear or diff gear should only change the gear ratio eg. acceleration/top end speed...the pro has the same grade metal as the standard and other version apart from the diffs of coarse they have different diffs from the standard ones not sure which diffs come with the tq but i presume it's the same as the standard hyper 7...just make sure you have the mesh correctly adjusted to suite.
MassiveMods 04-08-2005 07:45 PM
RE: hyper 7 engine
man you wanna sell that 4 port ? they are the best hyper engine ever !!
Da Smak 04-09-2005 01:25 AM
RE: hyper 7 engine
The Pro runs the SAME diffs as the TQ, UNLESS you use the optional Torsen, the PRO UK runs Spiders for all 3 a standard. The 4 port is the better engine for longevity but the 8 port is a little faster with the same gearing. But it IS a straight swap. The only difference is the liner.
Goaferboy 04-09-2005 05:10 PM
RE: hyper 7 engine
so would i be able to just take the 4 port out and put the 8 port in its place? all the stuff you mentioned just confuses me. and i probably wont sell the 4 port, best to have a spare. this is just an idea at the moment. i dont even have the hyper 7 yet :D
evilstoat 04-09-2005 06:53 PM
RE: hyper 7 engine
****Yes it will fit straight in you have to change nothing**** most .21 engines will fit the hyper range, i have since owning my hyper 7 changed the standard 4 port for a rossi .21 circuit then to a pro uk boost...no difference with the engine mounts only the rossi has a shollower crank case so it was eating starter wheels but no strengthening to the clutch or spur gear is required...i hope this answers your qeustion,
Uberchav Alex Date 4/9/2005 7:25:42 AM
as for others i am quite familiar with all versions in the hyper range i was simply trying not to go into too much detail as described later in the post...
Goaferboy Date 4/9/2005 11:10:33 PM
...and i was actually talking about the grade of material that the clutch bell gear(pinion) and the spur which is attatched to the diff housing and explainig that the gear need not be strengthened, as the original qeastion was aimed at and anyway the pro r comes with centre torsen diff as standard
MassiveMods 04-10-2005 11:38 PM
RE: hyper 7 engine
ORIGINAL: Uberchav Alex
and the piston..
Da Smak 04-11-2005 04:02 AM
RE: hyper 7 engine
ORIGINAL: MassiveMods
and the piston..
LOL yeah, have you tried to buy a liner on it's own. If it's Brand new though you could just swap the liner as they aren't matched that well, well not as well as Piccos are.
