differential prob and question
as you can assume from the name of this post, i have a problem with my differential. it goes really rough when distributing unequal forces in the tires, resulting in that both turn exactly at the same speed. what do i have to do to stop this? does it need more loob? thanks for the help
RE: differential prob and question
You need to take the diff out and strip it down to see if any teeth are damaged inside...
Thats the most likely cause for a diff going notchy... If its just been built then maybe the shimming is incorrect also [X(] |
| All times are GMT -8. The time now is 05:03 AM. |
