RCU Forums
-   RC 1/8th Scale Buggies (https://www.rcuniverse.com/forum/rc-1-8th-scale-buggies-244/)
-   -   Wheels turn when i pull the pullstart!!!!! (https://www.rcuniverse.com/forum/rc-1-8th-scale-buggies-244/3003407-wheels-turn-when-i-pull-pullstart.html)
w4yne83 05-23-2005 02:58 PM
Wheels turn when i pull the pullstart is this good or bad?
ALSO
My car will start with the wheels off of the ground but not on?
ALSO
Engine cuts out when i brake?
ANY IDEAS?
Please help or its going in the bin!!!!!
UF DUB 05-23-2005 03:03 PM
RE: Wheels turn when i pull the pullstart!!!!!
your clutch is engaged all the time. sounds like bad clutch bell bearings. or the shoes are jammed open. check there first.
Bigchris090 05-23-2005 03:08 PM
this has one happend to me your clutch is the problem
w4yne83 05-23-2005 03:14 PM
What do i to fix it then?
This is a new problem for me.
Bigchris090 05-23-2005 03:21 PM
hi take off your clutch bell (the gear whats atached to the engine) check if the clutch springs are jamed, broke also check if the shoes on the clutch are worn out or melted.one my shoes melted to the bell gear and the same problem you have ocurred.
hope this helps.
zimzalahbim 05-23-2005 04:58 PM
sounds like the clutch bearings are bad
