RCU Forums
-   RC 1/8th Scale Buggies (https://www.rcuniverse.com/forum/rc-1-8th-scale-buggies-244/)
-   -   WHICH 1/8 BUGGY? (https://www.rcuniverse.com/forum/rc-1-8th-scale-buggies-244/3007959-1-8-buggy.html)
BMCALLISTER 05-24-2005 07:35 PM
WHICH 1/8 BUGGY?
Hello
I need your alls opinion on which buggy to go with. I was looking at the jammin or the hyper 7 pbs both rtr. Give me some pros and cons and which one i would be better off in the long run.
thanks
kicbacNrelax 05-24-2005 07:39 PM
RE: WHICH 1/8 BUGGY?
How much u willing to spend. Also i highly recomend you by a kit. Much better quality and u get to know your buggy.
jmaggio 05-24-2005 09:07 PM
i would say kit also but if you dont want to spend that much id say go with the h7,
Foxy 05-25-2005 01:20 AM
They're both good, but the Hyper comes with a .21 engine and a starter box which tips it just above the jammin (which comes with a bigger block and pull start I believe, correct me if I am wrong...) in my opinion.
Hummer Man 05-25-2005 07:43 AM
I would reccomend the Hyper 7 PBS...
Engrose 05-25-2005 07:53 AM
If you can afford it, then get the Jammin kit and choose an engine and radio that suits you instead of dealing with what comes with a rtr.
You also should consider that the Jammin is a new kit, whereas the H7 has been on the market for a long time. The H7 is a very good kit, but the Jammin looks just great in my eyes.
BMCALLISTER 05-25-2005 10:28 AM
i dont want to spend a fortune right off. I have a m8 that i would use for the car. I just dont want to spend alot right off and then the 1/8 class die down at our track. I would also like to have a buggy(rtr) that is easily upgradable with time and also plenty aftermerket parts. What is the difference in the pbs edition vs the prs?
Hummer Man 05-25-2005 03:57 PM
Do you mean PCR vs PBS? The PCR has lay down servos, lowering the center of gravity...
Foxy 05-26-2005 01:27 AM
ORIGINAL: Hummer Man
Yes..........and..........no, if you do a search you can find the last time we discussed this subject, but to cut a long story short.... The laydown servo lowers approx 1.17g, approx 1.3mm in the chassis, or something like that, basically having absolutely no meaningful effect on the handling whatsoever, that is not the real advantage of the laydown configuration. I am told that you get slightly more steering throw from the laydown version, but haven't seen them both together to know for sure. The disadvantage is that they (the laydowns) are a ***** to work on, and even the throttle servo configuration is slightly different. I looked at the evidence and decided on the PBS myself, as I tend to screw around with my steering settings frequently, and didn't want to waste time with difficult servo mountings. I have also heard of a couple of people who took the PCR and now wish they had the PBS...[:-]
Hummer Man 05-26-2005 07:28 AM
ORIGINAL: foxy42
I didn't say they greatly improved the handling... I just stated they will lower the center of gravity slightly!
Foxy 05-26-2005 07:46 AM
? I didn't say you did, I was just providing a little extra info...maybe I shouldn't have put 'yes....and...no', cos it does lower the cg, as you said.... Sorry for the confusion...
