RCU Forums
-   RC 1/8th Scale Buggies (https://www.rcuniverse.com/forum/rc-1-8th-scale-buggies-244/)
-   -   u tern when brake (https://www.rcuniverse.com/forum/rc-1-8th-scale-buggies-244/3061789-u-tern-when-brake.html)
kclv1988 06-10-2005 04:40 PM
u tern when brake
when i hard brake locking the weals my buggy makes a u-turn is this normal???
Goaferboy 06-10-2005 04:58 PM
RE: u tern when brake
you probably have the rear brake set too strong. you could try strenghtening the front brake to compensate or weaken the rear brake
P1NkPanSie 06-11-2005 02:52 PM
1 Attachment(s)
you can also put a peice of silicone tubing on the brake rod like this it damps the brakes a lil for smoother stops
Chex 06-11-2005 05:48 PM
it depends...your steering geometry could be off; on the other hand maybe some wheels lose traction before others resulting in the spin.
...as long as it doesnt do it while braking before the wheels lock then there shouldnt be a problem...once you lock the wheels the car is effectively out of any real control and will tend to spin round in the direction of any momentum it had before the brakes were hit.
basically DONT LOCK THE BRAKES
kclv1988 06-11-2005 05:52 PM
thanks guys i got it
