air filter elements
Hi everyone
I'm looking for the foam inserts for my Mayhem 26 rtr the track i am building is quite dusty right now until i figure out a watering system and it would be alot easier if i could just change out the filter instead of cleaning it repeatedly.All i really need is just the inserta not the whole assembly. If you know where i could buy them (say 6 of them) could you let me know the horizon hobby site didn't have them listed(or i didn't see them) thanks P.S. i would also need inserts for a ttr-s3 with a ofna picco 28 |
RE: air filter elements
I never had to buy extra filter elements so I'm not to sure where besides a LHS. Oil the inside of the air filter instead of the outside and get a dust boot to go around it. The track I run as usually does get watered down but sometimes it gets so dusty you can't even see your buggy down the back stretch and I never had a problem with a clogged filter. I did want to get a few extra elements for a while but just never got around to it :).
Here you go: [link=http://www.carolinasrc.com/webstore/Scripts/prodView.asp?idproduct=18]Mugen Foams[/link]
These are much higher quality than the Sportwerks foams and they are a perfect fit in the Mayhem filter assy. |
Thanks I'll give the Mugens a try.
| All times are GMT -8. The time now is 03:12 PM. |
