RCU Forums
-   RC 1/8th Scale Buggies (https://www.rcuniverse.com/forum/rc-1-8th-scale-buggies-244/)
-   -   Need to increase acceleration help!!!!! (https://www.rcuniverse.com/forum/rc-1-8th-scale-buggies-244/3269209-need-increase-acceleration-help.html)
Korn9898 08-16-2005 04:27 PM
do i richen or lean the LSN?????buggy just dont pick up speed like it should
Da Smak 08-16-2005 05:02 PM
RE: Need to increase acceleration help!!!!!
Clutch bell # ?
If you've gone too far in with the LSN this will starve it and then your screwed.
SManMTB 08-16-2005 05:03 PM
< Captain Obvious >
Depends if it's lean or rich!
</Captain Obvious >
Ybenjulkay2x 08-16-2005 06:53 PM
what engine you are running?
brokeneck 08-16-2005 08:19 PM
what temps u reading?
Korn9898 08-17-2005 12:44 AM
engine is the force .26 temps are about 230-250
plaidfish 08-17-2005 09:05 AM
is your top speed fine? what is the buggy doing when you punch it? if it sounds like it's got a low rumbling noise then takes off it's too rich....If it sounds like it just gets weaker the more you pull the trigger but then starts screaming and dies it's too lean.....seems as though you're too rich on the bottom (LSN)....turn it in just a crack at a time......I'd also richen your HSN before you get to the LSN...if you're running at 250 now you'll be hotter overall when you lean out the LSN.......
