RCU Forums
-   RC 1/8th Scale Buggies (https://www.rcuniverse.com/forum/rc-1-8th-scale-buggies-244/)
-   -   installing throttle return spring on lx comp (https://www.rcuniverse.com/forum/rc-1-8th-scale-buggies-244/3945062-installing-throttle-return-spring-lx-comp.html)
ajkehoe82 02-22-2006 01:06 PM
Is it possible to install a trs on an ofna lx comp? I can not find any information on installing one on a slide carb. If it is possible, where can I get one? How do you install it (if not too obvious.) I'm worried about my hump pack detatching because the connectors do not fit tightly and my failsafe would not work in this event :-( Any help is appreciated.
thanks
markpc 02-22-2006 02:37 PM
RE: installing throttle return spring on lx comp
you can buy connector safety clamps to prevent such things, or some simple sticky tape will do the job, or double back the cable and put an elastic band around (less messy). If you need a return spring because of the fear of the battery cable failing make sure the battery connections do not fail and the failsafe will do its job.
For most little problems use your imagination and look around your house for helpful items (pen springs, spray bottle tubes for emergency antenna etc).
You don't need to buy every little thing from the manufacturer IMAGINATION goes a long way.
