RCU Forums
-   RC 1/8th Scale Buggies (https://www.rcuniverse.com/forum/rc-1-8th-scale-buggies-244/)
-   -   Flywheel (https://www.rcuniverse.com/forum/rc-1-8th-scale-buggies-244/4163010-flywheel.html)
Jadefalkon 04-13-2006 10:04 PM
Flywheel
I'm looking to buy the OS .21 RG from Tower hobbies for my Kyosho Sports Inferno. It says flywheel part number KYOC3545 is required, but they don't sell it. Can someone tell me where I can find this part, or another flywheel that I can use for it? Also whats the lowest priced started box that I can get for it?
vti-chris 04-14-2006 03:15 AM
RE: Flywheel
You will have a hard time finding one.Get another engine.(Although i do prefer the RG over any other cheap engine).
Maybe someone else can help you on the RG fitment!!Maybe there is a different flywheel that will also fit.
Jadefalkon 04-14-2006 05:10 PM
RE: Flywheel
Ok, could someone recommend a different engine for me? This is my first car so I don't need a super power racing engine. I just use it for bashing. thanks
Super_Dave 04-14-2006 06:14 PM
RE: Flywheel
You shouldn't have to change the flywheel. No one that I know of has needed to change their flywheel when switching to the O.S. RG. You could also look into the mach .26 and sportwerks .26 both are $130-$140 (mach .26 has low end power and SW .26 has top end power).
For the starterbox I use the Ofna true start.
http://www.nitrohouse.com/starter_boxes.htm look for the part #10256. It works on 1/10 stadium trucks too just remove some screws and change the direction of the wheel. The 1/8 one is $99 but it comes with a power pannel (for a plug in glow ignitor) and a 12v battery. For the 1/10 one you need to buy a battery and switch the wheel around to fit an 1/8 buggy but it will be cheaper as well. http://www.nitrohouse.com/acces,_bat...6_chargers.htm they will have a 12v battery and charger on that page if you need it.
Jadefalkon 04-14-2006 06:34 PM
RE: Flywheel
Thanks Dave, can you tell me a site for those engine? Tower doesn't have them.
mgtman 04-14-2006 07:39 PM
RE: Flywheel
http://www.amainhobbies.com/product_...oducts_id/3475
JoeGibbs 04-14-2006 08:55 PM
RE: Flywheel
I just put a stock Mayhem flywheel, collet, and nut on my RG. They fit perfectly. The Ofna flywheel didn't fit perfectly on the RG, but worked ok.
Good luck
Super_Dave 04-14-2006 10:25 PM
RE: Flywheel
ORIGINAL: Jadefalkon
amainhobbies.com and horizonhobby.com has the mach .26 and sportwerks .26 engines. If your using a starterbox get the solid backplate for the engine as well.
whitetrashmafia99 04-14-2006 11:24 PM
RE: Flywheel
http://www2.towerhobbies.com/cgi-bin/WTI0001P?&I=LXHUC7
I baught the ofna compact 1/8th scale off road starter box off tower hobbies for 50 bucks and it works perfect for me.
I also baught the O.S. RG 21 for my buggy and im very pleased with it.
