for steering
would this servo be sufficent for steering an x-ray xb8 tq http://www2.towerhobbies.com/cgi-bin...?&I=LXBXA7&P=0
RE: for steering
that should be ok
RE: for steering
For the same price I would go with http://www2.towerhobbies.com/cgi-bin...?&I=LXTT13&P=7
This is an excellent servo for steering on 1/8 buggys, its a little faster and has more torque. |
RE: for steering
The airtronics servo isn't digital.
that explains the price thing.;) |
RE: for steering
the only reason is that i have a rebate where i can get the futaba one for like 60
RE: for steering
the fact that the airtronics isnt digital isnt realy noticeable. its a great servo; the standard by which others are measured. its fast and turns the wheels with authority. digital, IMHO, just isnt necessary, and this servo is a great example.
RE: for steering
Well, i used to say the same before i went digita:)
with the analog servos plus am radio there was a really noticeable lag between my commands and the time the servo would take to react (this has nothing to do with the servo speed itself) i'm sure you guys have noticed that when your at the other end of the track, your car reacts slower to your commands, good digital servos reduce this lag time to the point where it's no longer perceptible. To Darthball, if you don't have a FM or spectrum radio system the benefits of the digital servo are less apparent. The futaba is also water and dust proof and since you have a rebate for the futaba servos you should go for the 9350 or if you can spare 10 more $ get the S9351 wich is basicaly the best servo available from Futaba for 1/8 buggies all the Futaba sponsored pro's use this one. |
RE: for steering
ill go with the futuba cause i have a coupon for 30 dollars off any futuba product. also i have a nomadio sensor
RE: for steering
How about this baby then? [link=http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXLSX0&P=7#tech]Airtroniks Servo[/link]
RE: for steering
why not just get this one? [link=http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXHZR9&P=7]http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXHZR9&P=7[/link]
RE: for steering
ORIGINAL: 911 Well, i used to say the same before i went digita:) with the analog servos plus am radio there was a really noticeable lag between my commands and the time the servo would take to react (this has nothing to do with the servo speed itself) i'm sure you guys have noticed that when your at the other end of the track, your car reacts slower to your commands, good digital servos reduce this lag time to the point where it's no longer perceptible.To Darthball, if you don't have a FM or spectrum radio system the benefits of the digital servo are less apparent. The futaba is also water and dust proof and since you have a rebate for the futaba servos you should go for the 9350 or if you can spare 10 more $ get the S9351 wich is basicaly the best servo available from Futaba for 1/8 buggies all the Futaba sponsored pro's use this one. |
RE: for steering
im still gi=oing with the futuba because the coupon is only for futaba servos and that hitec is way over kill
| All times are GMT -8. The time now is 11:26 AM. |
