Rollcenter Question
I have a question on how to setup rollcenter properly. My buggy has outside and inside hole on top or each rear C-hub and the shocktower has 4 holes to connect the turnbuckle to it. I have noticed that many buggies have the inside bottom hole on the shocktower used and inside hole on top of hub at each wheel. Also how much toe and camber should the rear be setup after you change the top turnbuckle to these location?
Rockman |
| All times are GMT -8. The time now is 01:29 PM. |
