RCU Forums
-   RC 1/8th Scale Buggies (https://www.rcuniverse.com/forum/rc-1-8th-scale-buggies-244/)
-   -   Temperature Gun (https://www.rcuniverse.com/forum/rc-1-8th-scale-buggies-244/4212487-temperature-gun.html)
kyoshosan 04-27-2006 09:33 AM
Temperature Gun
Hi all,
I am looking for a good temperature gun but they all seem to have the EMISSIVITY FIXED at 0.95 ? is this the right value for aur glow engines ? Should i get one with the emissivity adjustable, what would be the correct value ?? thanks in advance.
Kyoshosan
flash07 04-27-2006 01:58 PM
RE: Temperature Gun
Why don't you just get the venom temp. Isen't it more accurate?
SManMTB 04-27-2006 02:07 PM
RE: Temperature Gun
ORIGINAL: kyoshosan
Hi all,
Kyoshosan
The $25 Duratrax has adjustable emissivity settings. It's an OK value, not perfect. It all depends on the material the surface is made of. Anodized, not anodized and even the color of the anodizing will change the emissivity of the material.
kyoshosan 04-27-2006 07:29 PM
RE: Temperature Gun
But We were supposed to measure the temperature at the glow plug, right ? i mean aiming the Head Button ?
SManMTB 04-27-2006 09:43 PM
RE: Temperature Gun
ORIGINAL: kyoshosan
Yes but you will measure over a larger area than just the glow plug.
At 1" distance you will measure a circle of 1" in diameter using the Duratrax sensor.
