WHICH ONE FOR THE ENGINE
I'M ABOUT TO GET A V-SPEC AND I HAVE A JP-1.MY LOCAL HOBBY SHOP SAID THE JP-1 IS THE BEST WAY TO GO.BUT @ ANOTHER LOCAL HOBBY SHOP THEY SAID EITHER THE OS 2050 OR OS 2060 IS BETTER FOR THAT ENGINE.SO WHICH ONE SHOULD I CHOOSE?SHOULD I STAY WITH MY JP-1 OR SHOULD I GO WITH ON OF THE OS PIPES?
RE: WHICH ONE FOR THE ENGINE
i'd stick with your jp1.
BUT Y WOULD I STAY WITH IT?Y IS IT BETTER?
There both low-end pipes but o.s. says to use their pipe on their engine because they make it. Jammin pipes are some of the best out now anyway
OOO OK THEN THANK YA!NOW I DONT HALF TO SPEND MY MONEY ON SUMTHIN I DONT REALLY NEED!
the JP-1 is good but the OS 2050 & 2060 are specifically designed to be used with the VZB-V-spec and you'll get the very most out of the engine if you use those OS pipes. But essentially the JP-1 or jp-2 would also suffice.
The 2050 will undoubtedly be the best pipe however they are far from cheap. The JP-1 pipe is considered one of the better pipes about and as such I certainly wouldn't invest the sort of money a 2050 costs for such a small difference in performance.
YEA I SEE NOW THAT THERES NO REASON TO PAY THAT MUCJ FOR SUCH A LITTLE BOOST.
| All times are GMT -8. The time now is 10:34 AM. |
