RCU Forums
-   RC 1/8th Scale Buggies (https://www.rcuniverse.com/forum/rc-1-8th-scale-buggies-244/)
-   -   Clutch Q's on sts engine (https://www.rcuniverse.com/forum/rc-1-8th-scale-buggies-244/5548360-clutch-qs-sts-engine.html)
lachy1 03-12-2007 02:17 AM
hey guys , i just finished installing my clutch on my new sts .21e, I have 2 questions, is it right for the clutch bell to spin freely with the flywheel not moving? and also, I broke one of my springs when i was installing the shoes so i am using a 2 normal springs and 1 stiff spring setup? is that alright? Its the Ofna blue alumiunium shoes.
Also i accidently turned the engine over about 3 times when installing the clutch, has this done any damage to the engine? as it hasnt been broken in?
cheers
lachy1 03-12-2007 04:02 AM
RE: Clutch Q's on sts engine
bump
fozzyuk 03-12-2007 06:43 AM
Hi
The clutch bell is supposed to spin freely.. the whole assembly locks up when the centrifugal force asserted on the clutch shoes is strong enough...
And
A lot of racers mix up clutch springs to give a different sort of Take up... it will work fine but feel a bit 'different' on pull away..
And
I don't know how you ,managed to turn it over if its new... blimey my STS would seize solid if i tried.. But it should be ok... i doubt it would have scored the bore up or anything...
