What pipe?
Hi,
I was wondering what the best low-mid pipe would be for the axial .28 spec 1s engine would be? I am looking at the jammin jp-3, would it be a good one? Thanks for any help |
RE: What pipe?
Yeah it should be pretty good. check out the JP-1 too for low-mid.
RE: What pipe?
yeh the JP-3 is more top end.
JP-1 low end JP-2 low-mid-little top end JP-3 mid- alot of top end |
RE: What pipe?
Alright thanks, I think i might go with the jp2 because i think it would be best with our track we run on. If there are any better pipes than the jp2 let me know.
RE: What pipe?
Think you better do some checking first as the JP 2 is for middle to top end.
http://www2.towerhobbies.com/cgi-bin...&I=LXMWE6&P=ML |
RE: What pipe?
the j-p3 is a all around pipe it is the jp 1and2 together.
RE: What pipe?
Just wondering have you run the JP 3? The reason I ask is many I talk to do not like it. Wish I had the money to get all 3!
RE: What pipe?
so the jp2 is a mid to topend pipe? i thought it was a low to mid. are there any other brands of pipes that are good?
Thanks |
RE: What pipe?
yeah i like the jp-3 pipe i like the feel it gives the motor alot of people i know use them.
RE: What pipe?
Do you race and if so what track?
RE: What pipe?
JP-1 low end JP-2 low-mid-little top end JP-3 mid- alot of top end The JP-1 gives all bottom and takes a LITTLE off the top the JP-2 gives a little bottom and good top. and the JP-3 gives veary little low-mid and alot of top. The JP-3 was made to be an all aroud pipe, but I heard from a guy that has ran all three said that above^^^ That the JP-2 is about the all around pipe. I have also heard that the JP-2 has almost natice I said ALMOST as much bottom as the JP-1 just with more mid-top, and the JP-3 has more top than the JP-2. |
RE: What pipe?
Has to do what track, engine and the driver. Most tracks I run are very technical and most run the JP-1.
RE: What pipe?
I have the JP-3 and my Dad has the JP-2. all I need is the JP-1 and I'll have all three:D
RE: What pipe?
Alright thanks for the help, are there any other low to mid pipes that are better than the jp1? are the vantage racing carbon fiber pipes better? are there any other pipes that are good?
RE: What pipe?
RB 053 pipes are pretty good on low end. Don't know if they're better than the JP-1 but you're in the same territory (OFNA/Hong nor do a clone too)
RE: What pipe?
alright ill check that one out too, do you think it would work well with the axial .28 spec 1s engine?
Thanks |
RE: What pipe?
I'm afraid I have no experience with axial engines. It has worked well on the engines I have tried it on though. I don't see why not, I just can't guarantee it.
RE: What pipe?
alright thanks, i added that one to my list too. are there any other pipes like a novarossi or something like that that would work?
RE: What pipe?
http://www.amainhobbies.com/product_...oducts_id=2113
Would this be just as good as the RB 053 pipe? and do you think it would be better than the jp1? Thanks for the help |
RE: What pipe?
Thats the OFNA clone I mentioned. It will work fine.
RE: What pipe?
alright i think i will see if i can order one of those and some fuel, do you know of any good places that sell byrons fuel and that ofna clone pipe in the U.S.?
Thanks for all the help and if you know of any other pipes that are better let me know. |
RE: What pipe?
Well i'm in the UK so i can't help you there. I got mine off ebay though. I got an 086 top end pipe too and can't fault either. I don't know its better than the JP-1. They seem very similar to me. See which one you get cheapest :D
RE: What pipe?
alright, i think i can get the 053 cheaper so ill probably get that. do you know of any good fuel? what do you run and does it allow your engine to last a long time?
thanks |
RE: What pipe?
http://www.amainhobbies.com/product_...ducts_id/11351
would this pipe be any better than the 053? would it still be good in the low-mid but a little better in the topend range too? Thanks for any help |
RE: What pipe?
^oh nevermind about that pipe^ because it doesnt come with a manifold and thats what i really need to replace on my buggy, and i dont wanna spend that much because then i wouldnt be able to get new tires and everything but what fuel is the best in your opinion
thanks for the help |
| All times are GMT -8. The time now is 04:23 AM. |
