Mamba Motor Binding Problem
I have a Mamba 5400KV Motor which is fine in the forward direction but will not run in reverse. When I rotate the shaft by hand in reverse it appears to bind and stops rotating backwards within two turns of the pinion. Do any of you know how to solve this problem?
How do you dismantle the motor to look inside? Thanks |
RE: Mamba Motor Binding Problem
check the electric pages dude
| All times are GMT -8. The time now is 08:08 AM. |
