RCU Forums
-   RC 1/8th Scale Buggies (https://www.rcuniverse.com/forum/rc-1-8th-scale-buggies-244/)
-   -   MBX5R Diff Install (https://www.rcuniverse.com/forum/rc-1-8th-scale-buggies-244/6018710-mbx5r-diff-install.html)
mbx5r4life 06-21-2007 10:31 PM
MBX5R Diff Install
Dang it, one instruction book tells me to use the small o-rings in the front and center diffs, while the supplemental instruction manual says to look at the spec sheet. The spec sheets (I think) tells me not to use the o-rings and different weights for the diffs. Which one is correct?
911 06-21-2007 11:22 PM
RE: MBX5R Diff Install
don't use the small o-rings anywhere, they cause the diffs react inconsistently over longer periods.
dicko 06-21-2007 11:26 PM
only use the o rings on the out drives that seal the diff, not on the internal gears. and upgrade to the carolinas O rings, the stock ones leak.
common diff oil use is 5000 7000 2000 or 5000 7000 1000 front to rear, depends on your style & track conditions. 5, 7, 2 is most common, i'd start there.
mbx5r4life 06-21-2007 11:37 PM
so only use the 5mm ones, not the 3mms?
911 06-21-2007 11:56 PM
ORIGINAL: newbie20066
exactly
mbx5r4life 06-22-2007 01:30 PM
Any other mods or parts not used that you guys can let me know about? This is my first nitro car, so I'm not too familiar with the install/mods. thanks.
STR33T_RAC3R 06-22-2007 02:33 PM
Some people have been saying the stock springs are to short/soft.
I use the O rings in the front and centre diff but not the rear like the instructions said. And run 5,000 in the front 3,000 in the centre and 1,000 in the rear.
It's a full out racing buggy it doesn't need any mods apart from a zip tie on the fuel cap. Although i have seen somewhere that someone put a three brake disks on instead of two.
911 06-22-2007 03:34 PM
don't neglect loctite...
loctite is your friend...
dicko 06-24-2007 05:49 PM
i use 2 gaskets on my diffs to help give them a better seal and it gives a better gear mesh too.
mbx5r4life 06-24-2007 06:06 PM
Hope this is all right. On the center diff, one of the screws that holds the diff together (one of four on the gear) won't tighten. No matter how much I try, it just spins.
dicko 06-24-2007 09:26 PM
if there's no silicon oil in there put a drop of CA glue in there & put the screw back in. if there's silicon oil in there there isn't much you can unless you buy a new case.
STR33T_RAC3R 06-25-2007 02:07 AM
It sounds like youve threaded the diff caseing. You can probably get a new one for not much more than $10.
