Anybody use high torque servos for throttle?
It seems that most people run high speed servos for the throttle/brake and high torque for steering. My issue is that I don't seem to have enough braking force on my ravager. Granted it's the stock RTR radio, and perhaps a 5 cell reciever pack would help, but right now I can't adjust the brake bias without going to the extremes. If it's biased to the front, it has enough servo torque to lock up the front but barely touch the back. If I adjust them to be exactly the same, it doesn't have much brake overall. It's like the servo just doesn't have the balls to crank down on both at the same time with any force. My other though is that another radio that allows you to adjust the throw on the brake would help. More travel on the brake side. I did that on my rc10gt that has a better radio. Thoughts?
I'm thinking about upgrading to a better FM or spectrum radio anyway because of glitching, so maybe this is a pointless discussion. |
RE: Anybody use high torque servos for throttle?
I always say good transit speed high torque for steering, good torque high transit speed for steering. I use the futaba 3 pm 2.4 gig spectrum transmitter. It is very adjustable when it comes to steering and throttle trims. 10 model memory as well. just one idea. I also own 2 ravagers and it just takes a little time to get used to adjusting the brakes. If you can post a picture of your throttle / brake set up/ linkage. might be able to help
It'd be nice if the brake linkage had a turnbuckle, instead of just the moveable collar. unless you mark where you started from, it's easy to loosen the collar and have it move before you try to adjust. I still think a stronger servo would help. These spectrum radios are just soo crazy expensive. I know they're good, but spendy. I may just find myself a decent FM and invest in some good digital servos.
i run 2 x DS1015's on my hyper. One for steering and one for brake. I love it.
ORIGINAL: broncbuster i run 2 x DS1015's on my hyper. One for steering and one for brake. I love it. |
i run a htec 645mg for my throttle brake and a futaba high speed servo for the steering.
ORIGINAL: rammol i run a htec 645mg for my throttle brake and a futaba high speed servo for the steering. |
in my buggy i ran a 9000s for steering and 9000t for throttle and brake. since i got my truggy i now run airtronics servos in my buggy and i have the 9000s for throttle/break and the 9000t for steering
ORIGINAL: JRX2ER ORIGINAL: rammol i run a htec 645mg for my throttle brake and a futaba high speed servo for the steering. Not only that but the 645 is SLOW!!!!!!!!!!!!! |
1 Attachment(s)
I also run a HS-645G for my Ravager's throttle and brake. It used to coast to a stop and now will lock up all four if adjusted to that point! Ihavent gotten around to changing out the steer servo yet but it's a must.
You may want to look into a new radio if you are upgrading your servo. The stock radio has no end point adjustment that can lead to premature failure for the servo
ORIGINAL: silverj I also run a HS-645G for my Ravager's throttle and brake. It used to coast to a stop and now will lock up all four if adjusted to that point! Ihavent gotten around to changing out the steer servo yet but it's a must. If you ever run a faster servo even on the throttle and brake you will never go back to the SLOW 645! I ran a 645 and until I ran faster servos I never realized how slow the 645 really is. |
JRX2 if you want to run a high torque servo on your throttle n brake you can, but I would recomend a JR9000s for that with a 5 cell reciever pack and a good radio. I'm running this setup on both my Turmoil and my 8ight T and have no problems locking up the brakes, but I have my radio setup so it won't lock up.
I run a Futaba S9451 for throttle/brakes and a Futaba S9351 for steering.
ORIGINAL: rmesa1 You may want to look into a new radio if you are upgrading your servo. The stock radio has no end point adjustment that can lead to premature failure for the servo |
ORIGINAL: silverj I also run a HS-645G for my Ravager's throttle and brake. It used to coast to a stop and now will lock up all four if adjusted to that point! Ihavent gotten around to changing out the steer servo yet but it's a must. |
For steering: 150-200oz torque / .10-.15sec speed
For throttle: 100-130oz-torque / .10-.13sec speed I use hitec 5985 172oz/.13sec for steering Ko propo 2001 FET 100oz/ 0.08sec for throttle. Just a note: the ko seems to be the same speed with the hitec when on the car...this is because it doesn't spin freely any more...it's hocked up on the brakes and throttle. In my opinion torque is more important but make sure you are lower than .15 in speed. |
ORIGINAL: JRX2ER ORIGINAL: silverj I also run a HS-645G for my Ravager's throttle and brake. It used to coast to a stop and now will lock up all four if adjusted to that point! Ihavent gotten around to changing out the steer servo yet but it's a must. |
ORIGINAL: Da Smak ORIGINAL: JRX2ER ORIGINAL: silverj I also run a HS-645G for my Ravager's throttle and brake. It used to coast to a stop and now will lock up all four if adjusted to that point! Ihavent gotten around to changing out the steer servo yet but it's a must. Do any of the newer radios monitor reciever battery strength? |
Yes the React monitors both the TX and RX as well as much more. But I still run a spring as sanction racing requires it.
i am thinking of changing my servos the other way around. thanks guuys for all of your help. lol
In running airtronics 94758 servo for the gas/brake and a jr 9000t for steering. The best thing you can do for any servo is going to lipo pack. I dropped a 2000 mah with a 5amp regulator and it last all day without a charge. The servos stay at the .06 speed (gas/brake) and makes every run feel the same.
I know this is an old thread, but I finally got my new servos installed the other day (both were reverse direction from what I took out, so the first thing I did was strip my servo horn, need to get some AL ones), and after some sorting I have to say it's a phenomenal difference. Especially the stronger throttle/brake one. It's a hitec HS-965MG, and the brakes finally work as intended. It has a ton of stopping power. the ACE DS1313 is a huge improvement for steering too. Definitely worth doing.
Good choice...I use that 965 on the throttle on my revo. Fast little bugger.
iam runing 2 futaba bls451 , crazy fast and strong , they turn very easy on power off so i have a rubber on the carb to the servo horn to bring it back if something goes wrong :)
| All times are GMT -8. The time now is 02:29 PM. |
