RCU Forums
-   RC 1/8th Scale Buggies (https://www.rcuniverse.com/forum/rc-1-8th-scale-buggies-244/)
-   -   Rear diff fluid? (https://www.rcuniverse.com/forum/rc-1-8th-scale-buggies-244/6555034-rear-diff-fluid.html)
notch 9 10-29-2007 04:50 PM
Rear diff fluid?
Here's a strange question, Will different wieght fluid in my rear diff help me as I am still learning to drive. The model is a sportwerks turmoil rtr mostly upgraded to the pro version. Wondering if I should go with a 2000 or 3000 fluid in the rear on a 5-7-? set up. thanks.
kojak61 10-29-2007 05:03 PM
RE: Rear diff fluid?
5-7-3 is a normal baseline setup. I would try that then go higher or lower.
hrdcoreglf 10-29-2007 05:05 PM
5-7-3 is a average set up for all purpose driving. Changing diff set up depends on where you are running, and what track conditions are.
Rockman 10-29-2007 08:28 PM
Go with 2k in the rear to help with steering.
GRANT ED 10-30-2007 03:01 AM
IMO 3k for the rear is higher than average. Most pro setups use 2k or 1k.
Have a read of this.
http://users.pandora.be/elvo/
pete8541 10-30-2007 05:50 AM
My turmoil was pretty hard to handle, It was always loose. I ended up using 10-7-3 it worked about the best on the track that I run. When I went to other tracks I had to change. I have 7 loose diffs with differnt oils in in them for quick changes.
