RCU Forums
-   RC 1/8th Scale Buggies (https://www.rcuniverse.com/forum/rc-1-8th-scale-buggies-244/)
-   -   brake cleaner (https://www.rcuniverse.com/forum/rc-1-8th-scale-buggies-244/7498047-brake-cleaner.html)
youwish16 05-14-2008 11:57 PM
brake cleaner
i usually clean my buggy off with brake cleaner. i just bought i new polished pipe, will the brake cleaner damage the pipe? by damage i mean blemish it
ahawk65 05-15-2008 02:22 AM
RE: brake cleaner
I can't see any reason why it would. Try either spraying or dabbing a bit of the product you are using on an unnoticeable part of your pipe (on the underside of the belly, under the stinger, on the bottom of the manifold, etc.), let it dry, and take a look. Good luck, and congratulations on your new pipe! Post some pictures if you have any. =)
Themorales1999 05-15-2008 02:03 PM
RE: brake cleaner
So brake cleaner will not damage plastic parts? or stain the ionized aluminum part? Will carburator cleaner work the same?
r/c_noob 05-15-2008 02:56 PM
RE: brake cleaner
i think its better to use non chlorinated brake cleaner b/c it doesnt leave behind any kinda residue
slayerphonics 05-15-2008 02:56 PM
RE: brake cleaner
ORIGINAL: Themorales1999
I wouldn't use brake cleaner or carb cleaner,
carb leaves a perma stink on your truck, and leave a residue
brake cleaner leaves a perma stink on your truck and can damage plastics and electronics, if its chlorinated it will for sure damage your truck.
And it can cause harm to your skin
I would never use brake or crab cleaner on my truck.
The best cleaner is "Simple Green", its bio-degradable, it doesn't stink, it doesn't damage plastics.
Themorales1999 05-15-2008 03:25 PM
RE: brake cleaner
I've seen many who use Simple Green, do you wash it off with water or with an air compressor?
I use the water hose to take the big stuff off my buggy and then detail it with a humid rag. Recently I had a servo start acting crazy, I opened it up and found a little humidity. I let it dry and re installed it and now it work perfect. So I don’t know if the problem was the water hose.
slayerphonics 05-15-2008 03:40 PM
RE: brake cleaner
I've seen many how use Simple Green, do you wash it off with water or with an air compressor?
5 screws removes my radio tray, 4 screws to remove my motor,
then i just spray my truck down let it set for a min or so, hit with some water and air compressor it off right away,
only thing u need to watch out for is your bearings.
MorganSS 05-15-2008 04:14 PM
RE: brake cleaner
why on Earth would you need something so harsh??
simple green and an air compressor
youwish16 05-15-2008 04:56 PM
RE: brake cleaner
is simple green and mean green the same thing? i have mean green but i dont have an air compressor
rccheech 05-15-2008 09:39 PM
RE: brake cleaner
I know Cyclo non chlorinated brake clean is the exact same thing as the expensive nitro cleaner at a cheaper price, and non chlorinated brake clean will not harm electronics or ABS plastic based parts.
fasstrevo 05-15-2008 11:47 PM
RE: brake cleaner
Autozone brake cleaner is the best substitute I have found for nitro wash. Simple Green has it's place, but for cleaning greasy parts, glow plugs, etc. quickly you need a degreaser that dries quick. I buy a lot of it for basic degreasing and surface prep around my shop.
Please note - I have tried other types and brands of brake cleaners and some WILL eat plastic. I know the Autozone doesn't so I stick with it.
Calin666 05-16-2008 06:54 AM
RE: brake cleaner
Instad of brake or carb cleanerer, I use some stuff called "Gun Scrubber"
I actually use this for my firearms, but it works great on RC stuff. Leaves no residue, or scent.
There is two versions of it though, so be carefull. If you want to try it, make damn sure you get the "SYNTHETIC SAFE" version. It is made for using an plastic parts, and will not damage them. If you use the original, it will melt any plastic you use it on.
This stuff will get anything off, even hard, caked on, dried carbon residue that was been building up for 30 years. Best stuff I have found.
ProStreetCamaro 05-16-2008 08:41 AM
RE: brake cleaner
ORIGINAL: MorganSS
Bingo! spray it down with simple green. Let it sit a couple minutes then use an air compressor to dry it off. They always come out spotless if you do this process every time you run your RC.
slayerphonics 05-16-2008 02:42 PM
RE: brake cleaner
ORIGINAL: rccheech
Brake cleaner will damage plastics,
There is no reason to use such a harsh cleaner,
If you have that much grease build up on your truck, something is wrong with your engine.
RcRacer37E 05-16-2008 03:48 PM
RE: brake cleaner
I use crc brakleen on the engine, same stuff as nitro spray was just cheaper. I simple green every thing eles (remove radio box and servos in servo bracket) the hit it with a garden hose, 40 psi air the a bit of wd 40.
Stay away from oven cleaner, grease lightning and carb cleaner. They are evil, some remove anadize off aluminum and others eat plastic.
If you pick brake cleaner, look for the words, non-chlorinated, its safe on plastic like carb boot.
rccheech 05-16-2008 08:45 PM
RE: brake cleaner
Thank you!
McFly505 05-16-2008 11:17 PM
RE: brake cleaner
Very few brake clean sprays will harm plastic.
If they contain Acetone, MEK, or methylene chloride, they will eat/melt/destroy plastic of any kind, even Delrin.
Simple green and Mean Green will do the same thing, but Mean Green is about $3/gal at the Dollar store and a gallon will last all summer if you mix it 4:1 with water.
I use Mean Green, as described above (remove radio tray and engine), with ZERO issues and I like my stuff SPOTLESS.
EDIT<<<<>>>>
I use brake clean spray from O'Reilly Auto Parts.
I buy it by the case and use it to clean engine/clutch parts.
Here is another tip for you guys.
I'm a cheap skate, so I do it this way.
When rebuilding diffs, clean the parts in Naptha.
It dissolves the silicone oils and dries very quickly.
Leaves your parts sparkling clean in just a few minutes and it's cheap.
When washing air filters, use mineral spirits.
It dissolves the filter oil and doesn't break down the foam.
Let it dry for a few minutes and re-oil.
No water necessary.
Both of these chemicals can be bought at Lowes/Home Depot for about $8/gallon.
Scott
rclynx 05-17-2008 04:30 AM
RE: brake cleaner
If you have a compressor try spraying it down with WD40 and blow it off................if you do that all the time ,nothing sticks to it and it looks like new all the time ;)
